05 transmission.. To FLUSH or not to FLUSH?
Discussion in 'Technical Chat' started by Frankoo1234, Oct 28, 2011.
how do you service your transmission? people who dont tow
Poll closed Nov 27, 2011.
  1. dont mess with it let the stealership handle the FLUSH
    4 vote(s)
    28.6%
  2. let the stealership do a drain and fill
    1 vote(s)
    7.1%
  3. DIY drain and fill
    2 vote(s)
    14.3%
  4. just check the levels and add some if needed no biggie
    0 vote(s)
    0.0%
  5. study up on the flush write up and have at it ones your ready
    3 vote(s)
    21.4%
  6. iam to lazy to vote
    4 vote(s)
    28.6%
  1. Oct 28, 2011 at 7:53 AM
    Frankoo1234
    Frankoo1234 [OP] Well-Known Member
    OC
    Double Cab 05 Taco PreRunner
    Running boards, Tint
    so i just hit a little over 60,000 i have an 05 dc v6 automatic trans truck.. ive been reading a ton of threads on changing the transmission fluid.. or flushing it.. Iam not sure if its me or if the truck is shifting a bift rough these days.. at high speeds it shifts smoothly and when its warm and i have driven it part of the day it also shifts better.. it mostly happens in the morning when its cold or i havent driven it..
    some other info.. i believe the previouse owner did some but not a lot of towing but he also took care of the truck and had it serviced on schedule. (old mature rich guy type, nice person) i dont do any towing or offroading..
    so the question is should i service the trans fluid.. DIY drain and fill (ive practicly memorized that thread).. have the stealership do a flush on it.. or have the stealership do just a drain and fill and see if the shifting improves... i have also heard that if you disconnect the battery for a bit it resents the comp and the shifting habits..and does servicing it really change the feel of the shifting and stuff? like smoother shifting..? so what do you guys think.. sorry iam a noob and the one person i would ask (my dad) isnt near me.. and after reading countless threads iam more confused than anything.. drain and fill flush 100,000 or 60,000
  2. Oct 28, 2011 at 1:32 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It's just like any other peice of machinery that uses fluid. The fluid breaks down, especially from heat, and needs replacing. Considering you only replace a portion of the fluid when you drain, cooler and torque converter hold a few quarts, it's best to do it when recomended. Do it more often while towing.
    Heat kills transmission fluid, then it kills your transmission.
    I forgot to add:
    Some shops will do a "transfusion". They take off the trans cooler lines, draw out the old, while pushing in new fluid. This purges the cooler and flushes the torque converter. It is better than a drain and fill, but not necessary if you stick with the regular service intervals.
  3. Oct 28, 2011 at 2:40 PM
    Frankoo1234
    OC
    it runs around what 200 bucks at the stealership?
  4. Oct 29, 2011 at 5:18 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    just turned 100000 on mine and havent done mine yet guess its time
  5. Oct 29, 2011 at 6:23 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Keep an eye out for large metal flakes. Small ones are ok, so is the metal sludge. If your fluid smells burnt or is dark or brown, change it more often.
