05+ V6 Tacoma Steering Rack Bushing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyoTaco06, Aug 4, 2013.
  1. Jan 30, 2018 at 8:38 AM
    #141
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You know you're supposed to loosen the clamp at the top of the lower intermediate shaft, slide it up for enough room?
    Even so I found it impossible due to rust, so I cut everything off and replaced everything from the steering wheel down. Royal pain in the butt
    Crom likes this.
  2. Jan 30, 2018 at 8:55 AM
    #142
    jovol
    jovol Member
  3. Jan 30, 2018 at 9:40 AM
    #143
    jovol
    jovol Member
    Managed to get the steering sliding yoke off the first intermediate shaft, which made sliding the second intermediate shaft off the rack much easier. Took a lot of wd40, a hair dryer, and patience.
    TireFire and Crom like this.
  4. Jan 30, 2018 at 7:54 PM
    #144
    jovol
    jovol Member
    I finished up the job today. Definitely took a long while.
    On my test drive I noticed the steering wheel is off by about 90deg. It defaults to point at about 9oclock, and drives pretty straight at that. I’m guessing messed up the alignment when connecting the spline shaft to the intermediate shaft. Question though: can an alignment fix this, or do I have to disconnect the shafts and tinker with the alignment there?
    Thanks, John
  5. Jan 30, 2018 at 8:39 PM
    #145
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Im guessing you didnt lock the steering wheel? try to center the wheel and then re-connect it with the rack centered. If you leave the wheel like that and go for an alignment now you will be all screwed up.
  6. Jan 30, 2018 at 8:44 PM
    #146
    jovol
    jovol Member
    I tied the steering wheel down and marked the upper intermediate shaft, but my mark on the lower intermediate shaft and hydraulic control valve got wiped off, so I think the rack wasn’t straight.
  7. Jan 30, 2018 at 8:58 PM
    #147
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    guess you will have to go back down there and switch some stuff up till its right again! I would just resecure the steering wheel and eyeball the rack till everythings straight again. When i do stuff like this i usually like to make a small indent in the metal or something, or tap it with a chisel a few times then hit it with a marker.
  8. Jan 30, 2018 at 9:02 PM
    #148
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @jovol you'll need to undo your intermediate steering shaft and at least get it mostly straight. I went in to the alignment shop with an upside down steering wheel, and they couldn't do anything with that alignment wise.
    kaptankaos and MurderedTacoV2 like this.
  9. Jan 30, 2018 at 9:10 PM
    #149
    TireFire
    Olympic Peninsula
    That's sucks, you're definitely gonna have to figure out where it's off and correct. At least stuff will come apart easy now that it's fresh
  10. Jan 31, 2018 at 12:58 PM
    #150
    jovol
    jovol Member
    I adjusted it today and my test drive has it the steering wheel pointing at about 1oclock now :frusty:
    Should I suspect any other issues if my skid indicator light came on (and stayed on)? A did a search and I suspect its because my steering angle 0 point is off. If only I could just read a sensor value to get this all lined up.
  11. Jan 31, 2018 at 3:07 PM
    #151
    TireFire
    Olympic Peninsula
    Seems like you're getting there. Just overdid it by 30 degrees
  12. Feb 1, 2018 at 9:32 AM
    #152
    tacomawick
    tacomawick New Member
    Eastern Sierra, CA
    2009 4x4 AC V6
    Thank you. I was also having trouble getting the intermediate shaft to separate from the rack, but did not separate the sliding yoke. I will try that next time.
  13. Feb 1, 2018 at 11:34 AM
    #153
    jovol
    jovol Member
    It is done. After 3 adjustments the steering wheel is straight.
    Trick was to use ratchet straps on the wheel to hold it center. I was just using the seat belt, but it would turn ever to slightly when reconnecting the shafts. Two ratchet straps going to each sides’ pillar hand grab did the trick.
    Biscuits, Crom, BenMara and 2 others like this.
  14. Feb 1, 2018 at 11:38 AM
    #154
    TireFire
    Olympic Peninsula
    How the hell did you do it without loosening the sliding yoke?
  15. Feb 1, 2018 at 12:33 PM
    #155
    tacomawick
    Eastern Sierra, CA
    2009 4x4 AC V6
    Never got the intermediate shaft to separate, I ran out of time and had to put stuff back together so I could use the truck the next day. I wasted a bunch of time with a stuck TRE.
  16. Feb 1, 2018 at 2:05 PM
    #156
    TireFire
    Olympic Peninsula
    Wait, you changed the bushings on a 4x4 with the rack still on the truck AND the steering shaft still attached to the rack??? How??
  17. Feb 1, 2018 at 2:07 PM
    #157
    tacomawick
    Eastern Sierra, CA
    2009 4x4 AC V6
    Sorry for the confusion - I did not get the bushings installed on my first attempt! :oops:
  18. Feb 1, 2018 at 2:25 PM
    #158
    TireFire
    Olympic Peninsula
    Ahh, that makes more sense. Better luck next time!
  19. Feb 3, 2018 at 5:13 PM
    #159
    jovol
    jovol Member
    Since I finished up the job, figured I’d post things learned. This is for a 2010 4x4 with 135k miles.
    I referenced the service manual at this site: http://www.customtacos.com/tech.old/files/05FSM/repair.html for details and torque values.
    1. Much easier to get second intermediate shaft off if you separate it from the sliding yoke first.
    2. To get the driver side rack bolt out, I did a combo of loosening the 4 AC compressor bolts and the idler pulley next to the compressor. Cutting the bolt in that tight space while laying on the ground seems like total suckage.
    3. To finagle the rack out of the truck, I had to remove one of the big bolts for the front transfer case’s support arm on the passenger side.
    4. I loaned out the 5 piece pickle fork set from autozone. One of them was sized perfectly.
    5. I added less than one liter of fluid back into the system.
    6. Put a matchmark between the intermediate shaft and the steering rack.
    Hope that helps future hopefuls. Definitely was a bitch to do, but now I’ve done it once it would be easy to repeat.
    deanosaurus, TireFire and tacomawick like this.
  20. Feb 3, 2018 at 5:53 PM
    #160
    TireFire
    Olympic Peninsula
    Nice! But pretty sure you meant front differential and not transfer case
