05+ which lug nuts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RDAY, Jul 22, 2009.
  1. Jul 22, 2009 at 5:46 PM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    hubcentric or lugcentic which lug nuts and rings do i need for an 05 newer with aftermarket eagle alloy wheels. Also where can u order them?
  2. Jul 22, 2009 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All Aluminum wheels use "Shank" style lugs. 1.5 pitch.
  3. Jul 22, 2009 at 6:02 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    all that matters is the 1.5 pitch right? they can be 12 or 14mm it doesnt matter?
  4. Jul 22, 2009 at 6:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    whatever fits the holes. :)
  5. Jul 22, 2009 at 6:04 PM
    general61
    general61 Well-Known Member
    Ohio
    20 TRD OR
    12 x 1.5 shank style.....has to be 12mm
  6. Jul 22, 2009 at 6:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    the 12mm reffers to the length, and I think it depends alot on the wheel.
  7. Jul 22, 2009 at 6:09 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    alright what would u recommend if i have 12.1.5 right now but i cannot get the socket in to tighten them in the hole would u recomend going longer? im confused I thought this part would be the easiest also everyone keeps talking about getting those rings for our trucks or they will b off cenetered is this true?
  8. Jul 22, 2009 at 6:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You need a different socket. They have Thin Wall sockets for these lugs.
  9. Jul 22, 2009 at 6:18 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    oh ok if thats all i need im not to worried what about my center bore do i need the ring spacers to get it properly lined up do u think chris?
  10. Jul 22, 2009 at 6:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be fine without it.
  11. Jul 22, 2009 at 6:25 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    can i get the thin walled sockets locally or do i have to order online?
  12. Jul 22, 2009 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check a local Hardwaer store, or Sears. They should have them. Maybe even an Auto Zone or the like.
  13. Jul 22, 2009 at 6:26 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    also sorry for the dumb question but what size socket is it i don't remember what i was using earlier.
  14. Jul 22, 2009 at 6:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Varies. I cant remember what the OEM lug is, and I dont have mine anymore, so I cant measure for ya.
  15. Jul 22, 2009 at 6:30 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    man i just wanna make sure i actually get the right socket for the lug nut ill just take them with me thanks alot for the help chris.
  16. Jul 22, 2009 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Anytime. :)
  17. Jul 22, 2009 at 7:07 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    13/16"
    Also, the 12M is the size of the STUD/bolt not length. Go buy a M12Xwhatever length bolt and a M14Xwhatever length bolt and see what you get.
    The lug is a 12M X 1.50 pitch. You'll need a shanked version, and there are two common sizes. Make sure you get the correct size to fit the hole in your wheel. If you get the smaller lug diameter you will have issues. LUGcentric will not be so good.
  18. Jul 22, 2009 at 8:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ah HA!!!!
    Thanks for clearing that up. I was told it was the length of the stud, hence the length of the nut.
  19. Jul 22, 2009 at 8:30 PM
    general61
    Ohio
    20 TRD OR
    I should have read your first post a little closer( I'm on vacation and have had a couple too many:D) I have not sold any eagle wheels in a while but..........they should have a conical lug seat. This should enable you to get a regular set of lugs anywhere you want. I think close to 90% of lugs on the aftermarket side are conical. I'll call my local guy tomorrow and find out......very few wheels have a shank style lug hole anymore. To make a really story short........its super easy to F#*k it up if the wheel has shank style lug(plus almost every auto manufacturer has switched to conical style lug wheels). If your wheel has a flat lug seat....its a shank lug seat. If it looks like a funnel(for lack of a better explanation) it takes a conical lug. Good luck.......
