05 X Runner starting issue HELP!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BFRENCH, May 5, 2021.
  1. May 5, 2021 at 10:56 AM
    BFRENCH
    BFRENCH [OP] Active Member
    Brandon
    2005 Tacoma X Runner
    Like the title says my X Runner was running fine and I have checked every fuse and relay. Pulled and tested the starter. Pulled and tested the neutral safety switch and ignition all are fine. Here's the kicker battery is a newer optima yellow top (has full power). I turn the power on and it has power, but when I try to turn the motor over there is nothing. All grounds are good. Is there something I'm missing or something you guys have run into that I can't find. It was running fine last week.
    Thanks!
    Gunshot-6A likes this.
  2. May 5, 2021 at 11:06 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Take a few deep breaths and try to be a little more clear on what is and is not working.
    Is the starter turning the motor over? doesn't sound like it but I can not tell from what you have posted
    Or is it turning over but not actually starting?
    Gunshot-6A and Geeves77 like this.
  3. May 5, 2021 at 11:19 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Based on symptoms as described, starter relay/solenoid.
    Also, check that the inside of the battery terminal clamps aren't corroded. I had that issue on my 1st gen. Had to jump it all day until I realized how caked the inside of the clamps were and spent some quality time with a screw driver.
    BassAckwards and SR-71A like this.
  4. May 5, 2021 at 11:26 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    May also ohm out the POS lead to the starter
    whatstcp and Gunshot-6A like this.
  5. May 5, 2021 at 11:50 AM
    BFRENCH
    Brandon
    There was a new clamp put on the negative terminal last fall and the solenoid to the starter is fine.
    I appreciate the input. I described all this to my toyota service tech (buddy) and they are just as baffled. I'm at the point of possibly ripping apart the harness to see if there is wire housing issues
  6. May 5, 2021 at 11:52 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Fuel pump issues? It is an older vehicle. Although tacomas aren't known to have fuel pump issues, it can still be something to troubleshoot.
  7. May 5, 2021 at 11:53 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I'd be willing to bet that you have a problem with the immobilizer system, happened to a friend recently.
    dk_crew likes this.
  8. May 5, 2021 at 11:59 AM
    BFRENCH
    Brandon
    Interesting I'll have to look into this after work
  9. May 5, 2021 at 2:42 PM
    Waasheem
    Waasheem
    2007 xrunner
    It sounds like you have a no crank issue. Or does it crank but fail to start the engine?
    Assuming it’s a no crank, chances are good it’s your starter solenoid internal contacts. Optima isn’t what it used to be so I’d look there first because it’s easier. My multimeter has a peak hi & low feature, not all do. Or if you have a old analog dial volt meter it’ll work. Hook to your battery terminals, try to start, your looking for what the voltage drops to at it’s lowest. Starter voltage drop test. 10.2-10.5 is considered ok, lower than that the battery is kaput. Engine off you should have 12.5 or higher. Engine running you should see around 14.2, 13.5 is a little weak, more that 14.7 is overcharging.
    On mine, I did away with the clutch switch deal, removed the relay & put in a bypass wire, my switch was bad and I hated having to stomp the clutch to start, lazy. Also, I get an occasional no crank. I’m planning to do the denso solenoid rebuild kit soon.
    Gunshot-6A[QUOTED] likes this.
  10. May 5, 2021 at 2:48 PM
    BFRENCH
    Brandon
    Waasheem-I have done all this already, but thank you for the input. The battery and solenoid and it's contacts are fine as well. I'm honestly resorting to the harness at this point.
  11. May 5, 2021 at 2:56 PM
    Waasheem
    Waasheem
    2007 xrunner
    You could try bypassing the clutch switch. At the switch would work to test, at the relay would be better if you want to leave it in.
    My switch tested bad so maybe yours is too.
    You could also try holding the key to crank and stomping the clutch up and down.
  12. May 5, 2021 at 3:10 PM
    Lefthook
    Lefthook Well-Known Member
    New jersey
    2014 DCLB
    Tonneau cover
    Before you start ripping your wiring harness apart, I would check to see if you have power at the starter motor battery cable and the trigger wire while cranking. If you do not, get a wiring diagram for your vehicle and start checking for proper power and grounds starting from the trigger wire back to the ignition switch. I would also check every under hood fuse and under dash fuse with a test light to make sure they are all good.
    b_r_o and TnShooter like this.
  13. May 5, 2021 at 3:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree.
    Check for power at the appropriate places.
    This may help - https://www.tacomaworld.com/threads...ve-another-update.652013/page-5#post-22812853
  14. May 5, 2021 at 6:13 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    My girlfriend had a corolla that would do the same thing - randomly not start
    Drove me crazy
    The previous owner had replaced one of the batter terminals with an aftermarket aluminum one
    I switch that over to a Toyota type (steel) and never had problem again
    Not sure why but for some reason the replacement didn’t alway allow current
  15. May 5, 2021 at 6:26 PM
    Waasheem
    Waasheem
    2007 xrunner
    BassAckwards and Jimmyh like this.
  16. May 5, 2021 at 6:51 PM
    BFRENCH
    Brandon
    Have done all of this, but again thank you all for the help and input
  17. May 5, 2021 at 7:48 PM
    BFRENCH
    Brandon
    Hmmm I believe I replaced the clamp with steel, but I'll double check tomorrow. I really hope that is the problem lol
    tacofish[QUOTED] likes this.
  18. May 5, 2021 at 7:54 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
  19. May 5, 2021 at 7:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    So are you getting power at the little trigger wire in the crank position or not?
  20. May 5, 2021 at 9:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    OP says he checked everything, but not giving us much information to go on.
    How did you check the starter contacts? (the only reliable way to check these is by opening up the solenoid and looking)
    Is there a single small click then nothing?
    Is there voltage at the battery connector at the starter?
    Does the voltage drop when trying to crank at the starter connector?
    Is there voltage at the Solenoid Coil Wire when trying to start?
    CraigF, BassAckwards and Torspd like this.
