05 X Runner starting issue HELP!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BFRENCH, May 5, 2021.
  1. May 5, 2021 at 9:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This may assist you in your quest.
    BassAckwards and 6 gearT444E like this.
  2. May 5, 2021 at 9:40 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    To bypass and rule out the immobilizer, you can pull the start relay and jumper across the 3-5 contact to try and "bump" the starter motor with the ignition switch in the start position. If it doesn't spin or click, you have a starter/wiring issue to the starter. If starter makes no noise during the bump; either your start relay is bad which you can bench test at that point or you have a wiring issue going from the ignition switch to the starter. Dumb question, but did you verify the 7.5A start relay is good with a multimeter?
    Jimmyh likes this.
  3. May 6, 2021 at 6:26 AM
    BFRENCH
    BFRENCH [OP] Active Member
    Brandon
    2005 Tacoma X Runner
    Yes I have pulled apart the starter and checked all this. Even my dad who is a mechanical/chemical engineer and my buddy who is a Toyota service manager and master mechanic is baffled. He is looking into what's going on and he believes it might actually be in the wire harness as well.
  4. May 6, 2021 at 10:26 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    no offense to your pops because I am an engineer, they are typically not good at diagnosing field issues, and are usually better off in the lab designing something new
  5. May 6, 2021 at 1:26 PM
    BFRENCH
    Brandon
    Maybe not, but in the twenty years I have been building vehicles and motorcycles with him we have never been this perplexed about something. He's pretty good at electrical diagnosis as well. Even my cousin who has his master's in electrical engineering and has built vehicles with us is stumped.
    I mean when two engineers and a Toyota mechanic can't figure it out I throw my hands up to the car gods in mercy
    tacofish and 6 gearT444E[QUOTED] like this.
  6. May 6, 2021 at 4:09 PM
    Waasheem
    Waasheem
    2007 xrunner
    I'd try this. Run a jumper wire from the y-g wire on the starter to up close to the battery. There's probably a connector you could disconnect, connect the jumper wire to the starter instead of the wire going up to the relay. Of course take all precautions, not in gear, jumper wire isn't near moving or hot parts. Turn the key to on. Now just touch the wire to the positive post, it should begin to crank, be ready to disconnect quickly once it starts if it starts. If it does start, you know the starter is in fact good but the power isn't getting to the starter when the key is in the start position. Sometimes there's a fusible link on the y-g wire right next to the starter. Maybe its bad. You could also test the y-g wire going to the relay, it should get power when the key is in the start position.
    If anyone has issue with this test. I won't be offended and prefer you say don't do that.
  7. May 6, 2021 at 4:59 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    That’s essentially the same test I tell him earlier. Bypass the relay and relay coil and send 12v fused directly from the ignition switch to the starter solenoid. Back in the day, you could just do this by unplugging the small signal wire and sticking a screwdriver across the two posts.
  8. May 6, 2021 at 5:50 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    For the 3rd time..
    in the crank position, is there power on the Y/G trigger wire at the starter?
    blu92in99 and 6 gearT444E like this.
  9. May 6, 2021 at 6:04 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    how many engineers does it take to change a light bulb?
    Steves104x4 likes this.
  10. May 6, 2021 at 10:52 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Looking at the starter circuit then looking at the OP's postings and I am too perplexed.
    I am truly puzzled that the combined efforts of a mechanical/chemical engineer, a Toyota service manager and master mechanic and a master in electrical engineering cannot figure out a basic starter circuit.
    Not trying to be rude, but it isn't rocket science. Look at the circuit drawings, they are at the depth of a Basic Electrical Class.
    You say you have checked these things below 1.) 2.) and 3.).
    What were your findings of the voltage readings? Give us something here.
    Three things are required to get the starter to turn:
    1.) A good ground return connection. Starter is grounded to the block via mounting.
    2.) A solid 12 vdc at the battery terminal at the starter connection Black Wire w/Red Stripe.
    3. A solid 12 vdc at the Yellow Wire w/Green Stripe when the key is turned to the start position.
    If all three of those things were good then the starter motor should have turned. If it did not then the starter motor/solenoid is the problem.
    I wish you luck in finding the answer.
    Please update this thread when you find the elusive answer.
    Dm93 and 6 gearT444E like this.
  11. May 7, 2021 at 8:02 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Maybe I am missing these points. Does the starter spin when keyed? Did that get answered already?
    Pretty certain that I never saw if there was a mention that the motor spun (cranked) or not. Does it spin?
    When the key is on, and the dash illuminates, then you turn the key to try to start the engine. Do the dash lights dim?
    Has the started been pulled and bench tested?
    Here is an old video of "bypassing" the circuit to bump the starter.
    https://youtu.be/CXxddyaRr5c
  12. May 8, 2021 at 5:20 PM
    BFRENCH
    Brandon
    My buddy is opening up the harness now and his exact words were "rut roh" lol. I just said take pictures and send me texts if you can. I'll update when I'm updated.
    Julioezavala and Steves104x4 like this.
  13. May 8, 2021 at 5:32 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Soy wiring has failed us once again.
    Torspd likes this.
  14. May 9, 2021 at 5:31 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Please do post pictures and information on what was found.
    6 gearT444E likes this.
  15. May 9, 2021 at 6:52 PM
    #35
    Waasheem
    Waasheem
    2007 xrunner
    Spidey sense is telling me rodent damage
    SR-71A likes this.
  16. May 10, 2021 at 7:59 PM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    Well? Any News?
  17. May 10, 2021 at 8:17 PM
    #37
    6 gearT444E
    Deep South
    Herculiner Hootus
    Jimmyh[QUOTED] likes this.
  18. Dec 7, 2021 at 10:48 PM
    #38
    Julioezavala
    Julioezavala New Member
    Julio
    05 xrunner and 08 prerunner
    Did you find out what was going on with your truck.
    I have had the same issue with my xrunner lately. Replaced cables and switches and starters galore!!!!! Starter at least 3 times!!
  19. Dec 8, 2021 at 12:29 AM
    #39
    Jimmyh
    SC
    2012 Prerunner SR5
    If you follow along the thread here you should be able to figure out the issue. See post # 30 and the Schematic in post # 21.
    Chances are he is long gone as he hasn't been seen since:
    BFRENCH was last seen: May 8, 2021
    TnShooter likes this.
