05s the only year for the bad motor mounts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OH-MAN, Apr 18, 2010.
  1. Apr 18, 2010 at 7:54 AM
    OH-MAN
    OH-MAN [OP] Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Might be looking at a nice 06 soon and everything I see about the motor mount problem was in the 05s. Is this correct?
    I checked the TSB list and did not see it.
    Was it a full recall?
    Any other things anyone has run into on the 06 models to look for?
  2. Apr 18, 2010 at 7:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Early 06's had the issue. Seems the latter ones dont.
  3. Apr 18, 2010 at 8:02 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    Thank you sir.
    I will be under it with a flashlight checking it out.
    How did they repair it?
    From the pics I have seen it looks like the weld was overpenetrated and broke the frame along the mount weld.
    Seems like they would have to replace a section of the frame to do it right.
  4. Apr 18, 2010 at 8:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not sure how it was repaired. If you want, I can inspect the truck for ya.
  5. Apr 18, 2010 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The build date is on the door jamb.
  6. Apr 18, 2010 at 8:09 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    I will see it Wed. the 21st for the first time.
    It is being traded in at my good friends dealership and he knew I was looking for one for my kid.
    I appreciate the offer and may do that after I see it.
    Thanks Chris
  7. Apr 18, 2010 at 8:11 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    06 TRD Prerunner
    My 06 TRD Prerunner (mfg date 06/06) does NOT have the "updated" motor mounts.
    I check them every oil change or whenever I'm under the truck.....
