'06 2WD PreRunner with no zerks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cmoore, Feb 4, 2020.
  1. Feb 4, 2020 at 3:44 AM
    cmoore
    cmoore [OP] Well-Known Member
    Charlie
    Dallas, Texas
    PreRunner
    I've had this truck since new and it's been a joy to own. Now for the first time at 136K I'm getting a scraping type sound when I put it in reverse. The sound speeds up and slows down with the movement of the truck so I'm about 95% certain it's coming from the drive shaft. I've got no zerks on the U-joints or the carrier bearing. Do I have any options to get grease in without replacing the u-joints and carrier bearing? The U-joints seem to be solid so it could be just coming from the carrier bearing. Thanks for your help.
  2. Feb 4, 2020 at 5:06 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    IF the universal joints are making noise they need to be replaced, not greased.
    136K with no grease, replace them all with universal joints with grease fittings. Then grease every oil change or at a minimum every other oil change.
  3. Feb 4, 2020 at 7:14 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  4. Feb 4, 2020 at 9:49 PM
    oceanslide
    oceanslide Well-Known Member
    Erik
    Oceanside, CA
    2006 Access Cab
    5100s, OME 885
  5. Feb 5, 2020 at 4:05 AM
    cmoore
    Charlie
    Dallas, Texas
    PreRunner
    Thanks for the replies. Looks like I need to start gathering up parts. Oceanslide, I don't know the difference between the two spicer u-joints you listed. I'm going to be doing some research on parts before I pull any triggers.
  6. Feb 5, 2020 at 11:50 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Make sure you mark the driveline,so you put it back together and back on the truck in exactly the same way it was orientated when you removed it.
