06 4 wd sport making loud noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justintheegreat, Mar 30, 2016.
  1. Mar 30, 2016 at 7:01 PM
    Justintheegreat
    Justintheegreat [OP] Well-Known Member
    Northern CA
    06 DCSB Sport
    Every time I start my truck I have this loud noise in the engine bay. Can't pin point the problem. Was thinking I had a vavumme leak but found nothing. Replace both donut gaskets post cat.
    Friend suggest nay be a pulley going out. He told me to spray some WD40 I'm there one by one and start it and see which pulley it was but I havnt tried just yet.
    Any suggestions?
    I cant really describe it. Just sounds like a loud vacuum leak or something. Sort of like when you breathehot air into your hands. But louder. :mad:
  2. Mar 30, 2016 at 7:07 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Probably a pulley, pull the belt and turn them each by hand to see if they feel funny or make any noise.
  3. Mar 30, 2016 at 7:14 PM
    Justintheegreat
    Northern CA
    06 DCSB Sport
    I'll try that. Should it just sound smooth or ?
  4. Mar 30, 2016 at 8:20 PM
    shakerhood
    Southern Ohio
    It should feel smooth, if it feels notchy or is binding then its bad.
    httuner likes this.
  5. Mar 31, 2016 at 10:49 AM
    Justintheegreat
    Northern CA
    06 DCSB Sport
    Now if it's been doing it for awhile. Is it possible that I messed something else up or is it just the noise that's annoying. I figured maybe some dirt got in there
  6. Apr 1, 2016 at 1:27 PM
    Justintheegreat
    Northern CA
    06 DCSB Sport
    So removed my belt. I see one belt tensionsor and like 3 other pullys that I guess keep the belt in place.(gold)
    Some felt smoothie and the others just sounded like the bearings where a little dry.
    Sprayed some white silicone grease inside them. And cleaned up the excess.
    Still has the sound.
    Honestly sounds like an exhaust peak or something but I'm not sure.
