06 4x4 won't engage
Discussion in 'Technical Chat' started by danknutson, Nov 21, 2010.
  1. Nov 21, 2010 at 12:57 PM
    danknutson
    danknutson [OP] Digger
    Digger
    Saskatchewan
    06SR5
    3" lift
    My 06 Automatic won't go into 4x4 light just blinks at me
  2. Nov 21, 2010 at 1:11 PM
    nastyblowpop
    nastyblowpop Well-Known Member
    Long Beach, CA
    08 DC 4x4 rugged trail
    are you moving when your trying to engage it? it wont engage if you are sitting still..you only want to be still and in neutral to go into 4L. hope this helps. it also helps to be on dirt.
    and if you havent used it much or at all its a little finiky. try driving forward and turning the wheel back and forth until it locks.
  3. Nov 22, 2010 at 5:44 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    ^^ If these suggestions do not work or after a couple of days of trying...its probably your actuator.
    My truck did that on my 06 & the dealer had to replace that part to make it engage.
    There are similiar threads on here by others on the same issue.
  4. Nov 22, 2010 at 5:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    4wd will engage if you are sitting still and in neutral. That's the only way i've ever engaged mine. It takes a couple seconds though, the light blinks a few times then finally goes solid. I usually use mine for getting in and out of parking spaces so engaging while moving isn't really an option... if I could get moving I wouldn't need 4wd in the first place. Turning the wheel back and forth a little bit will help it engage sometimes.
  5. Nov 22, 2010 at 5:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    My 4wd HI will engage sitting still in drive.
  6. Nov 22, 2010 at 6:03 AM
    Pugga
    Massachusetts
    Haven't tried in drive yet... I'm used to my other trucks that had that damn floor shifter where you had to be in neutral, sitting still and all the stars and moons had to align just right, then maybe it'd engage if the truck felt like it!:cool: Definitely liking the switch on the dash so far.
  7. Nov 22, 2010 at 6:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    If you do it while rolling, I suggest getting completely off the gas. It will elimnate binding and pop right in. It will still work if you are on the gas, you just may hear a popping sound.
  8. Nov 22, 2010 at 8:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are we talking about just 4WD hi? Or 4Lo?
    You should be able to engage 4WD at any time. I can engage mine into 4WD hi while driving.
    4lo range is different.
  9. Nov 22, 2010 at 3:25 PM
    danknutson
    Digger
    Saskatchewan
    06SR5
    3" lift
    turns out it was frozen, last time I used it it was around zero C and sloppy wet, now it has dropped to -21C. dealer told me to get it inside and thaw the truck out, after it warmed and I switched it back and forth a few times it kicked in.
  10. Nov 23, 2010 at 5:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    Gotta love those easy fixes.
