'06 automatic won't start, no crank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dianna, Jul 10, 2015.
  1. Jul 10, 2015 at 3:44 PM
    Dianna
    Dianna [OP] Well-Known Member
    Dianna
    Ohio
    -06 Tacoma Sport -77 FJ40 -14 4Runner Trail Premium -19 Tacoma TRD Sport Cement Gray
    Hi guys, I have an '06, auto, and I haven't driven it for a couple of months because it is stuck in park. I haven't had a chance to try to fix that problem and now the truck will not start, no click, nothing. I did remove the shifter cable from the transmission, I don't think that would cause my problem, would it? If so, I did push in the button on the shifting column while trying to start, still nothing. Any help would be greatly appreciated!
  2. Jul 10, 2015 at 3:50 PM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    What position is your trans range sensor in (on trans) if your shifter is in park and the range sensor is in gear truck will not start
    Drivesector likes this.
  3. Jul 10, 2015 at 7:33 PM
    Dianna
    Dianna
    Ohio
    It was in park when I removed the shift cable from the transmission.
  4. Jul 10, 2015 at 7:42 PM
    offthewallsurfer
    offthewallsurfer Well-Known Member
    Battery
    Avsfreak18 likes this.
  5. Jul 10, 2015 at 8:17 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Your battery is probably dead That is why it wont shift out of park There is a manual release that you can push to release it I believe its under a tab next to shifter Or just install a charged battery. If this corrects it then next step is find cause of dead battery.
  6. Jul 10, 2015 at 9:19 PM
    Dianna
    Dianna
    Ohio
    I charged up the battery and tested it, battery good and no start. Just to make sure it wasn't the battery, I pulled the battery out of my FJ40 and put it in and tried, nothing. I tool the cable that attaches to the starter off and cleaned it up, still nothing.
  7. Jul 10, 2015 at 9:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Does it turn over, but just not firing?
    Does it click and not turn over.
    Do the lights come on?
    If it doesn't do anything, but the battery is charged - It could be the park / neutral safety switch. Try putting the shift lever in neutral and starting it that way. As per your original post you will have to press the Park Override button under the cover at the forward end of the shift lever to get it out of the park position.
    How to adjust the Park Neutral safety switch:
    http://www.customtacos.com/tech.old...6toyrm/06toypdf/06rmsrc/rm2006ta/02800510.pdf
  8. Jul 10, 2015 at 10:02 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
  9. Jul 10, 2015 at 10:09 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What are you trying to say NSS?
  10. Jul 10, 2015 at 10:14 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Neutral Safety Switch, it let the ECU know you're not in gear while you're trying to start the vehicle.
  11. Jul 10, 2015 at 10:21 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Are there any other things that aren't working right when you turn the key on?
  12. Jul 12, 2015 at 8:08 AM
    Dianna
    Dianna
    Ohio
    Everything else works, there is enough juice to put windows up and down, battery is at 100% and tests good with a tester, again, I tried a different battery just to make sure that wasn't the issue. I have the transmission cable disconnected at the transmission, I tried starting it in neutral (the shifter in neutral, as the transmission is frozen in park) with the override button pushed in, nothing.
    I do not get a click, no crank, nothing when I try to turn it over.
  13. Jul 12, 2015 at 3:13 PM
    bubbabud
    Bob
    Tonopah AZ
    Electrical problems are hard to diagnose long distance. A couple of suggestions 1st down at the starter you stated you cleaned and tightened the battery cable at the starter check the small wire on the solenoid clean and tight. then use a screw driver or short jumper and cross the battery cable to the post that the small wire connects to this will engage the starter if there is power to it. If the starter works next step check the large fuses in the power dist. box under the hood also check the other bundle of smaller wires that connect to the starter with the batt cable. 2nd check batt ground cable for clean tight connection at both ends. I recommend that you reconnect the trans. shift cable and use the park release button to shift. If the starter does not work when you jump it then the starter, solenoid is bad or there is no power getting from battery to the starter possible bad cable or ground. hope this will get you started [pun intended] on your search for a fix.
  14. Jul 12, 2015 at 4:19 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    My money is on Jimmyh
  15. Jul 12, 2015 at 7:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You will need to actually put the transmission in neutral, that is where the safety switch is. Why is the transmission frozen in park?
    Reconnect the linkage to the transmission.
    Use the push button to release the shifter and place it in neutral.
    Then try and start the truck while wiggling the shifter in neutral.
    What good does it do to start the truck if it is stuck in park?
  16. Jul 12, 2015 at 7:53 PM
    Canufixit
    New England
    IMO you need to go back to the original problem. Get the issue with the shifter /cable fixed and then check the adjustment including switch adjustment for both park and neutral positions.
  17. Dec 22, 2017 at 2:11 PM
    Greg miller
    Greg miller New Member
    05 Tacoma
    Replaced engine
    I have a similar issue with my 05 no fuel pump or start no crank either I have power to the starter relay on crank but starter doesn't work
  18. Jan 15, 2018 at 11:10 AM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    Did you get this sorted out after ?
    Tacoworld88 likes this.
