06 coolant flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smuehl99, Jun 9, 2016.
  1. Jun 9, 2016 at 8:19 AM
    Smuehl99
    Smuehl99 [OP] Well-Known Member
    Sam
    Montgomery county, PA
    2006 TRD Sport DCSB
    is there any write-ups or how to's for a second gen coolant flush and fill? thanks.
  2. Jun 9, 2016 at 9:04 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    use the search function..."2005 tacoma coolant flush"
    there is plenty of threads
    it's quicker than waiting for someone to post it for you
    fairly easy, drain then fill, you could replace thermostat and hoses at the same time as well
  3. Jun 9, 2016 at 9:55 AM
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    That's not a flush.
  4. Jun 9, 2016 at 10:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    There's nothing special or tricky about the cooling system that I've read about.
    Just about any generic write up / you tube video on doing a coolant change or coolant flush should apply.
    I've only had a couple of old beaters I drug home that deserved an actual pressurized 'flush', or back flush. In both of those cases the effort cost me a water pump and a radiator, both of which I sort of expected to happen.
    If the goal is to refresh the coolant properties, an actual 'flush' should not be needed.
  5. Jun 9, 2016 at 11:32 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Agreed. With these trucks, you only need to flush a cooling system that's neglected. Otherwise, drain the block and the radiator and replace any old belts or hoses as necessary. Reconnect everything, and fill her up with the correct fluid (SLLC). Also be sure to put fresh fluid in the recovery tank. Top off after a few heat cycles. Boom you're done.
