06 dbl cab blown 10amp fuse! towing problem!
Discussion in 'Towing' started by peotaco, Jul 5, 2009.
  1. Jul 5, 2009 at 8:28 AM
    peotaco
    peotaco [OP] Member
    peoria
    trd offroad
    I have a 06 double cab. It didn't come with a tow package. I but a hidden hitch and a plug and play adapter for the wiring on it. I hooked up my motorcycle trailer and have had NO problems, but when i hook up my jetski trailer I keep blowing the 10amp fuse behind ( the one located behind the change holder). I looked at the engine fuse box and it was missing the two 30amp fuses for towing. I installed them and i am STILL blowing the 10amp fuse. What is going on? I am hoping its just the jetski trailer. I have a buddy with a tacoma w towing who is going to try hooking it up to his tomorrow. I just wanted to ask if there were any other fuses that i need to do.
  2. Jul 5, 2009 at 8:35 AM
    peotaco
    peotaco [OP] Member
    peoria
    trd offroad
    also...if i buy the 4flat tester from walmart will that tell me if its wired correctly? (that way i would know its the trailer)..its just bugging me because its not blowing the fuse w my motorcycle trailer.)
  3. Jul 5, 2009 at 10:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like the problem is in the Jet Ski trailer... Go thru the wiring and make sure nothing is grounding out. Also, is this, by chance, happening when you back the trailer into the water, or before?
  4. Jul 5, 2009 at 10:21 AM
    peotaco
    peotaco [OP] Member
    peoria
    trd offroad
    its happening on the driveway...yeah i hope its just the trailer...
  5. Jul 5, 2009 at 10:47 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    sounds like its somthing sHorting to ground
  6. Jul 5, 2009 at 12:28 PM
    VancityCK
    VancityCK Well-Known Member
    Vancouver
    09 Magnetic AC TRD Offroad
    Trailer problem. Sounds like truck is fine. If you can't figure out the trailer wiring yourself, call a hitch installer. If it's a simple solution, a nice one will do the fix for free, if it's not, well, they're the guys to go to anyway.
  7. Jul 5, 2009 at 3:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add, you can re wire the trailer yourself for about $25.00...Icluding new lights.
  8. Jul 5, 2009 at 3:55 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What chris said. I had a friend with a 1980 something buick and a Hobie Cat sailboat....Beat ass old trailer....He kept blowing his shit up with it and had no clue what was wrong.
    I took one look at the wires and found 2 leaks and a split wire that was grounding. The new wires are easy to pull.
    Good luck!!
  9. Jul 10, 2009 at 3:36 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I would look at the wiring adapter you bought. The Tacoma needs one that basically copies the signals from the tail wiring, using power from a different source, and sends it to the trailer. The Toyota wiring kit includes the 2 fuses, and the wiring connects at the dash, not the back of the truck. This is where the power for the trailer lights should come from. Cheap wiring kits are cheap for a reason....You might be able to get away with connecting a trailer with fewer lights your wiring, does the jet ski trailer have more lights?
