06 losing cooling really fast
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacrod, May 23, 2019.
  1. May 23, 2019 at 7:12 PM
    tacrod
    tacrod [OP] Active Member
    Just noticed that my 06 tacoma is losing coolant really fast I'm filling my coolant every time I drive the truck. Even on quick 5 minute drives. Check engine light came on and I noticed the temperature gage go almost all the way up so I had to stop and noticed I had an empty coolant reservoir. When stopped I hear a lot of gargling and notice a lot of spilling. Not sure how to go about diagnosing. Any thoughts? Thanks
  2. May 23, 2019 at 7:16 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Head gasket is probably shot. I’d put money on it.
    whatstcp and wilcam47 like this.
  3. May 23, 2019 at 7:17 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Head gasket is toast. My condolences. It's a pricey fix.
  4. May 23, 2019 at 7:18 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Take your truck to a trusted mechanic and have him/her diagnose your issues.
    blu92in99 likes this.
  5. May 23, 2019 at 7:19 PM
    tacrod
  6. May 23, 2019 at 7:22 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Yup like others said head gaskets are gone. Common issue for that you Tacoma. You’ll have to decide if the truck is even worth the investment but maybe you know a trusted mechanic.
  7. May 23, 2019 at 7:23 PM
    Bishop84
    Bishop84 Well-Known Member
    If you do end up doing the headgasket, consider replacement of timing chains and tensioners.
    It's expensive but worth the investment.
    DO NOT USE STOP LEAK
    TrailYeti, blu92in99 and SocalTaco15 like this.
  8. May 23, 2019 at 9:11 PM
    tacrod
    thanks for advice guys
  9. May 23, 2019 at 9:15 PM
    Muddinfun
    Muddinfun Well-Known Member
    Wait! Hold the phone! OP has a 2.7. Isn't there a coolant bypass line that goes on the 2.7?
  10. May 24, 2019 at 2:34 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Stop guessing and fill it up with water and go get a loaner radiator pressure tester (most auto stores loan them) and pressurize the system and find the leak location - anyone can do this simple and easy.
  11. May 24, 2019 at 5:52 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Riiiight... I'm sitting here picturing someone ripping their head off to do head gaskets "cuz the internet told me to!" with a cracked radiator tank... or a FUBAR water pump seal... or a rotten hose...
    Maybe even start with the simple... fill it up with water cold, put the cap back on, squeeze the upper rad hose and see if you can see the leak...
  12. May 24, 2019 at 5:58 AM
    GMan8402
    GMan8402 Well-Known Member
    98 SR5 4x4 / 14 Prerunner TRD OR 4x2
    Wouldn't a gasket leak that bad cause a lot of white smoke from the tailpipe?
    wilcam47 likes this.
  13. May 24, 2019 at 6:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    Spilling from where?
    Not being rude here. Seriously. But if you don't know, it's time to pay a pro. The diagnosis is fairly rudimentary in the mechanical world, even if the repair winds up being complex.
    Want to try self diagnosis first? Good idea if you are wanting to learn. Do this
    If you want to give diagnosis a shot, this is how ^^
    All the folks shouting head gasket may be right. Or not. Sometimes we get a lot of exercise leaping to conclusions.
    We don't know what engine you have, where the coolant spilling is coming from, etc etc. Don't start panic mode yet.
    HillJackJDS and blu92in99 like this.
  14. May 24, 2019 at 6:11 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Could just be a radiator cap. That thing is like 10 bucks. Have someone get in the truck and rev the engine. If you see a bunch of white smoke coming from the exhaust, probably blown head gasket. Also open the coolant reservoir, you may be able to see it bubbling while the engine is running. 99% of the time that is a head gasket. Try running the truck and look for a coolant leak. Could be a loose or blown hose. Don't jump to conclusions and assume its a head gasket.
    Clearwater Bill likes this.
  15. May 24, 2019 at 7:38 AM
    81shark
    81shark Well-Known Member
    yup. and it's plastic. runs under the intake manifold.
  16. May 24, 2019 at 7:51 AM
    TrailYeti
    TrailYeti Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
    sub'd for outcome. :popcorn:
  17. May 24, 2019 at 7:54 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    if it was a headgasket it would be blowing white smoke like a damn chimney at that rate, you guys are always so quick so jump on the headgasket bandwagon lmfao.
  18. May 24, 2019 at 8:00 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    I dont think it's been asked but is the coolant spilling out onto the ground or is it disappearing?
  19. May 24, 2019 at 8:46 AM
    Sharpish
    Brian
    If there's a leak it should be trickling onto the ground pretty steadily at idle. I think we assumed he looked for a puddle in his driveway.
  20. May 24, 2019 at 8:52 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    only other place for it to go other than the ground or exhaust is the oil. check the oil dipstick for coolant in it. a leak that big should be noticeable.
