06 losing cooling really fast
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacrod, May 23, 2019.
  1. May 24, 2019 at 9:01 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    agreed...mine, alao an 06 just started leaking the other day, it was a slow seap and i replaces it before i had any serious issue last weekend.
    check to see if its driping on the driver aide seemingly from under the ac compressor, if so id bet a dollar that yoyr leak is the bypass line.
    the entire repair inclusing manifold gasket can be done yourself in a couple hours and for less than a hundred bucks!
    Muddinfun likes this.
  2. May 24, 2019 at 9:55 AM
    Bishop84
    Bishop84 Well-Known Member
    Headgaskets fail internally, causing burning of coolant and various times of the warm up.
  3. May 24, 2019 at 10:28 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Yeah no shit. People were saying we shouldn't jump to conclusions that it was the headgasket. I'm saying we jumped to that conclusion because a big cooling system leak should be fairly obvious, as in a big puddle of coolant in his driveway.
    He also didn't specify the engine, being an 06, the 4.0 was prone to head gasket failure with the exact same symptoms he is describing.
  4. May 24, 2019 at 10:31 AM
    eon_blue
    Azusa, CA
    A HG leak that big should be very apparent in the oil, if I were OP I would do an oil change and see what it looks like...post a pic on here for us.
  5. May 24, 2019 at 10:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    That's true. But when you click his name and check a couple other posts, you'll see he has a base 2.7.
    Well, he did say
  6. May 24, 2019 at 11:30 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    06 Head gasket!
  7. May 24, 2019 at 11:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    :rolleyes:
    He has a 2.7
  8. May 24, 2019 at 11:44 AM
    spot
    spot Well-Known Member
    Jon
    Surry
    06 DCSB Tacoma
    ARB Front Bumper Fox Extended RR w/ 650 coil LR UCA All Pro expedition Leafs Icon 2.0 Aluminum rear shocks All Pro Steel Pac Rack
    Water pump
  9. May 24, 2019 at 11:52 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    With engine completely cool remove the radiator cap and fill up to the neck with coolant. Start the engine and let it idle. Look inside radiator for 10 minutes or so and watch for gas/bubbles. If is does that you do have a head gasket failure which is pushing the coolant out of the system on the compression stroke. White smoke/steam out the exhaust indicates coolant being sucked in from a crack in the gasket on the intake stroke, converted to steam when fuel is burned, and then blown out with the exhaust.
  10. May 24, 2019 at 3:19 PM
    lynlan1819
    Tacoma
    Lifted
    I never said he had a 4.0,most likely he has a failed head gasket.
