06 manual third gear grind
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bm@StAugbeach, Oct 19, 2020.
  1. Oct 19, 2020 at 12:26 PM
    Bm@StAugbeach
    Bm@StAugbeach [OP] Member
    Brett
    2006 Tacoma
    06 Tacoma TRD off Road manual 6speed shifting into third gear grinds? Put new clutch in couple years ago.
  2. Oct 19, 2020 at 12:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Or a worn syncro gear.
    Torspd likes this.
  3. Oct 19, 2020 at 1:18 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I'd start by changing your MTF first. I purchased my truck with about only 30k miles on it, it was on OEM fluid still and it would often grind or feel notchy especially when it was cold and 3rd gear seemed to be the worst. I was gonna go the MT90 route but ended up putting in fords synthetic MTF. The nice thing is you can get it locally at your ford dealer but it is more expensive than some other options. Have had mine in there for about 80k and I can say it got rid of any notchy or grinding feeling issues even when cold and it is still working great.
    This is the stuff I'm talking about:
    https://www.truckid.com/motorcraft/...ennCIOyTKMhqE-Jkuzu9c6y5XpVxjTt0aAqFSEALw_wcB
    Amazon also carries it if that's your thing:
    https://www.amazon.com/Genuine-Ford-XT-M5-QS-Synthetic-Transmission/dp/B000NUES82
    I hear Redline MT90 does work great too but I haven't used it.
    whiseve likes this.
  4. Oct 19, 2020 at 2:37 PM
    Bm@StAugbeach
    Brett
    2006 Tacoma
    Yes when it’s a little cooler out or when I first run her she tends to grind going into 3rd gear. I’ll have to try it. Thanks so much y’all!
  5. Nov 11, 2020 at 1:44 PM
    Bm@StAugbeach
    Brett
    2006 Tacoma
    Not sure what that is? Can you explain. Toyota said you may need to replace transmission if it keeps getting worse.
  6. Nov 11, 2020 at 3:10 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Mine had same problem and I dumped the oil. Replaced with Redline MT 90 and the problem went away. Needless to say I am pleased.
    Strictlytoyz likes this.
  7. Nov 11, 2020 at 4:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It speed matches the gears while shifting gears so that it doesn't grind.
    https://www.youtube.com/watch?v=nM4CuWlnJY0
    Marc70, DiscoYaker and mojojojo78 like this.
  8. Nov 12, 2020 at 6:58 AM
    Bm@StAugbeach
    Brett
    2006 Tacoma
    Jimmyh[QUOTED] likes this.
  9. Nov 12, 2020 at 11:25 AM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Great share.. really helps with a person like me to understand how things work. Im a visual/hands on learner.
  10. Nov 12, 2020 at 1:51 PM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Try double clutching 3rd. If it doesn't grind, likely the synchro is gone. I had a manual ranger that had the 2nd gear synchro go out without notice/warning. Just stopped working when I got off the highway. I just double clutched 2nd for about a year and a half until I got rid of it (and got my new to me 2013 base Taco). Wasn't worth fixing/replacing since it had 290K at that point.
    Marc70 likes this.
  11. Nov 12, 2020 at 2:19 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Jimmyh and DiscoYaker like this.
  12. Nov 12, 2020 at 3:16 PM
    DiscoYaker
    SE USA and Alaska
  13. Nov 12, 2020 at 5:51 PM
    TacoTuesday1
    FL
    MT90 is probably not the best. I have it and am not satisfied.
    It's just overhyped and people repeat what they hear. It is easy for the average enthusiast who doesn't know how to drive to buy it and then pretend it's awesome. They don't know the difference.
    It's the same in the Audi world with Motul Gear 300. Also a synthetic 75w90. That is not that good.
    The few folks over there with half a brain all ended up eventually switching to something thinner/lighter like 75w80 for better synchro operation. And given that most manual transmissions only need to operate synchros, 75w80 probably works fine. Unlike a hypoid gear open rear diff or whatever, that may need strong gear oil only.
    whatstcp[QUOTED] likes this.
  14. Nov 12, 2020 at 8:27 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    This ^ and if that don't fix it its your synchros. I had a bad 3rd gear grind and mt90 made it dissapear
  15. Nov 12, 2020 at 11:10 PM
    TacoTuesday1
    FL
    Worth mentioning that 75w80 was Fuchs Titan SintoFluid of some sort I believe, maybe their SAE version
    there's a lot to pick from, both specific oil and different brands
    they may also have different viscosities in practice
    for example on motor oil, usually you can find a spec sheet on it. With stuff like HTHSV. High temp shear viscosity or whatever. And it will be different with different oils, even if both of them are "5w40" for example.
