06 MT drag/ resistance in 1st
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tathambenjamin, Nov 1, 2019.
  1. Nov 1, 2019 at 3:08 PM
    tathambenjamin
    tathambenjamin [OP] Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    Last two days I have felt a little bit of drag/ resistance as I let the clutch out to accelerate from a stop into 1st gear. It's not a lot of drag- just enough that takeoff isnt quite as smooth as before. No noises or vibrations. feels like maybe a brake shoe/drum dragging. However, not pulling right or left.
    I tried to search, but just saw a lot about rebuilding calipers. Has new brakes front and rear all around with the exception of drivers side caliper, which looked pretty good. Didnt replace wheel cylinder on rears either, but again, looked really clean. Had some trouble with brake cable being really loose when I got the truck, but it adjusted out fine when I replaced the rears.
    Anyone experienced this?
    Any guesses?
  2. Nov 2, 2019 at 8:23 AM
    tathambenjamin
    ben
    2008 4Runner SR5
    Also, started happening first two days of freezing temps since I have owned the truck. Anybody have issues with brake shoes/ brake cables freezing?
  3. Nov 2, 2019 at 8:27 AM
    Bishop84
    Bishop84 Well-Known Member
    I would suspect seized calipers. Changed a lot, especially 10+ year old models.
    Easy way to tell is to jack up each wheel and spin it, should spin freely.
    Hard way to is push each caliper back.
  4. Nov 2, 2019 at 8:29 AM
    tathambenjamin
    ben
    2008 4Runner SR5
    Already replaced pads/ rotors on both sides and caliper on pass side. I will have to take another look at drivers caliper, but didn’t see anything that looked like an issue when I did the brakes
