'06 Prerunner conversion to 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTacoPA, Oct 3, 2015.
  1. Jan 26, 2016 at 8:01 PM
    #81
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    OP, can you post Some pictures of shift level re-routing and how you sealed the hole in the floor.?
  2. Mar 23, 2016 at 11:18 AM
    #82
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    I want to do the conversion on my 14 tacoma prerunner, I want a manual fj cruiser transfer case, one question, I don't seem to find manual locking hubs, what can I do so when I run on 2hi, I get the front drive shaft and CVS free of spinning.?
    Also did you had to do a change of your computer?
    Thx, I went through all the posts of this thread. Nice!
  3. Mar 23, 2016 at 11:36 AM
    #83
    BryanR00
    BryanR00 Member
    Mobile, AL
    2011 PreRunner TX
    New 05-15 Tacomas don't have manual locking hubs. The differential lock is controlled by a switch inside of the truck that you can buy from Rock Solid Toys. When you shift into 4x4, you simply press this button to lock the differential then press it again when you're back into 2wd. The wiring and switch from Rock Solid Toys is like $130.
    Z E R 0[QUOTED] likes this.
  4. Mar 23, 2016 at 12:03 PM
    #84
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    You can make the switch for $20 and some beer as well
    Z E R 0 likes this.
  5. Mar 23, 2016 at 1:48 PM
    #85
    Z E R 0
    California
    02 Tacoma 4x4
    Great, so am i good with the fj tcase, And the front differential from a 4x4 tacoma?
    Is it easy to wire up the control switch? Do I have to do anything to the stock prerunner ecu?
    Thx a lot
  6. Mar 23, 2016 at 1:51 PM
    #86
    PSU Taco85
    optional
    Stock ecu goes in the trash
  7. Mar 23, 2016 at 1:56 PM
    #87
    Z E R 0
    California
    02 Tacoma 4x4
    What do you mean? :eek:
    Also with the rocks solid toys ADD switch, do I need the automatic fj tcase or manual? With actuator
    Thanks!
    Edit, I did found a thread on rocks solid toys, so every prerunner comes with the 4x4 ecu already? I saw that Is not needed anymore, like you mentioned.
    I just can't find where to buy the harness, I guess I have to create an account on their forums first... Or where?
  8. Mar 23, 2016 at 2:31 PM
    #88
    BlueTacoPA
    BlueTacoPA [OP] Active Member
    Bill
    Greenwood, SC
    2006 Blue Prerunner
    4x4 conversion w/ manual T-case
    What Bryan said above about the front diff. Your CVs are always going to be spinning. Your front drive shaft will not spin if you have the front diff unlocked with the switch from RST.
    I didn't change anything with my computer because everything works independent of it. I think there is a way to do this but is much more complicated.
  9. Mar 23, 2016 at 2:32 PM
    #89
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Study wyatt's thread on RST, pretty much everything you need to know is there. You can email Wyatt and it is $135 shipped for the ADD harness. You do not need to mess with the ECU.
  10. Mar 23, 2016 at 2:51 PM
    #90
    PSU Taco85
    optional
    The 4wd ecu is no longer needed with the Fj case. Prerunners do not have a 4wd ecu
  11. Mar 23, 2016 at 8:45 PM
    #91
    Z E R 0
    California
    02 Tacoma 4x4
    Great, I will contact Wyatt.
    Thanks for the help everyone, but I am sure I will come back to this thread, lol
  12. Mar 23, 2016 at 11:32 PM
    #92
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    Wyatt quoted me 10k just fyi
  13. Mar 24, 2016 at 9:26 AM
    #93
    Z E R 0
    California
    02 Tacoma 4x4
    I just need the switch hardness, what do you mean by 10k?
    Quewtion:
    I have a 2014 tacoma pre runner
    From what year of a tacoma can I get the automatic 4x4 transmission, CVS, drifmve shaft, frond diff?
    And what year of fj cruiser for the manual tcase?
    Thanks!!
  14. Mar 24, 2016 at 9:30 AM
    #94
    Iamraiderpower
    Iamraiderpower Well-Known Member
    I wonder how much this is going to cost ya :D
  15. Mar 24, 2016 at 10:04 AM
    #95
    PSU Taco85
    optional
    ouch, he does good work though.
    05-15 for the transmission, front diff, and CVs. And whatever year the FJ cruisers were available those will work too. The driveshaft you are better off sourcing from a junkyard and just getting it lengthened.
  16. Mar 24, 2016 at 10:30 AM
    #96
    ajohnson
    Andy
    Charlotte, NC
    I'm into my swap about $1600 so far, but have an electronic tcase I can sell (came with the trans I bought). Just need to get the front driveshaft flange from a buddy and probably retube my driveshaft with a slip joint. Taking my front diff to ECGS tomorrow for regear before I start the conversion (did not include regear with that $1600, it's optional).
    Edit; I also bought a URD 4x4 y pipe to relocate my crossover so there's that cost, I figured I'll pair it with my URD headers.
    I should come out pretty good if I can make some back from my 2wd trans and taco tcase.
  17. Mar 27, 2016 at 4:41 PM
    #97
    BlueTacoPA
    Bill
    Greenwood, SC
    2006 Blue Prerunner
    I believe the only person that offers a manual FJ case for this modification is Wyatt. That is who I went with. They are a little more than $900 but have been modified to be manual and have new seals and oil pumps. They come ready to bolt on to your 4wd tail housing. Others may know somebody else to get one from. I am not positive, but I believe you can't get a FJ t-case that is already manual. I think you have to get an electronic one and modify it. I could be wrong.
    Getting the manual sticks up into the cab was the most time consuming and difficult part for me.
    As Andy mentioned above, don't forget about the y-pipe.
  18. Mar 27, 2016 at 5:27 PM
    #98
    ajohnson
    Andy
    Charlotte, NC
    FJ cases are manual shift. It needs to be from an automatic trans model, you can find them on eBay. Wyatt modifies them for twin sticks which is not necessary just for the conversion. IIRC the 6 speed FJ's are full time 4wd and the cases are different.
    #98
    PSU Taco85 likes this.
  19. Mar 1, 2023 at 6:03 PM
    #99
    jamesdean118
    jamesdean118 New Member
    James
    2006 tacoma
    Swapped engine from pre runner to 4x4 engine
    I have a prerunner 2006, just got an engine from a 2006 4x4 both 4.0. Having problems with it staying running. Any info? Engine is good. Gives engine light now and dies. Think I need to change brain?
  20. Mar 1, 2023 at 8:43 PM
    #100
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    This is a 7 year old thread, I suspect the OP has moved on.
