'06 PreRunner needs Suspension Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by racerxmd, Jul 25, 2014.
  1. Jul 25, 2014 at 3:10 PM
    racerxmd
    racerxmd [OP] Member
    MD
    2006 Tacoma PreRunner SR5
    My '06 Double Cab needs some help. It seems to be bottoming out alot and was wondering if there are any up-grades I could do it. Would stiffer springs or heavier duty shocks help? If so, which ones would help?
    Thanks
  2. Jul 25, 2014 at 6:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you are talking about bottoming out with a load in the bed.
    WELCOME TO THE FAMILY.
    They have a TSB on the issue where they add an extra leaf spring.
    Since you have an '06 warranty isn't likely going to cover it for you.
    I would get an Add-A-Leaf myself.
  3. Jul 26, 2014 at 4:50 AM
    racerxmd
    MD
    I did a little research and thinking of purchasing the ARB Old Man EMU kit. The kit has higher rate coil-over springs and NitroCharger Sport Struts for the front. On the rear it takes the 5 Leaf Springs with 2 Helper Leaf Springs and the NitroCharger Sport Shocks. I think that it would help it out alot. Also, I believe it will raise the truck maybe 2". Just trying to find a place here in USA to purchase them from.
  4. Jul 26, 2014 at 5:00 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I just installed the OME Dakar leaf packs and it raised the rear to 26" hub to fender (its tall :p)
    The best price I could find for the OME leaf packs was from Down South Motorsports. Handling on the pair of springs was only $45. Other places were asking as much as $150 for shipping.
    If you don't mind waiting about 2 weeks I'm going to be selling my entire Toytec lift kit which includes Toytec front coilovers w/ Bilstein 5100 shocks, rear 4-leaf TSB springs with an additional Toytec AAL, rear Bilstein 5100 shocks, Light Racing upper control arms, extended u-bolts, axle shims, and sway bar relocation kit. I may also have extended stainless steel brake lines available around then too.
    I'm in Centreville, VA, close to Dulles airport. PM me if interested :)
  5. Jul 26, 2014 at 7:44 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Goijg back to stalk?
  6. Jul 26, 2014 at 7:53 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    iron man front coils rated for 275lb extra weight and dakar add a leaf, iron man struts in the front (made for 3" lift) and billstein 5100's (made for the 3" lift) in the back, i have a 2006, tried all kinds of stuff, this setup works perfectly! ride is better than stock on the road and great off-road! adds a little load capacity in the back to. highly recommend!
    i got the springs and leaf for 3" lift btw, not sure if you are wanting lift or not.
    i got billsteins from downsouth and springs, struts, dakars from toytec, doing every wrench turn myself i spent about $800
    you want "C" rated coils
    http://www.ironman4x4.com/suspension-kits/
  7. Jul 26, 2014 at 9:37 AM
    SManZ
    Fauquier County, VA
    Nope, upgraded to a King 2.5" remote resi setup with Total Chaos UCAs so the ToyTec lift parts have to go. :)
