06 Prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxWonderlandxx, Feb 17, 2022.
  1. Feb 17, 2022 at 2:21 PM
    xxWonderlandxx
    xxWonderlandxx [OP] New Member
    Alice
    2006 Silver Tacoma Prerunner
    I have a 2006 Pre-runner (automatic trans) When I've been driving lately it's been stuck in 4th and won't go into drive no matter what I've tried. Usually when this has happened I put some transmission fluid in and I'm golden but not this time. Suggestions????
  2. Feb 17, 2022 at 2:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d first want to be sure the truck is actually in “5th/D”.
    Does the dash indicate it’s in “D” or 5th?
    How have you been adding fluid?
    And are you sure the level is correct?
    These truck can be quite aggravating to fill correctly.
    Dm93 likes this.
  3. Feb 17, 2022 at 4:18 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Are you saying it not shifting into 5th? All “D” means is the the tranny is in the drive and has the option to shift into 5th which is actually overdrive in the 5 speed. A quick check is shift the lever while driving into the 4 position the back into D and see if it will shift into 5th gear. Also if you’re in 5th at 70mph you should be running 2100rpm approximately.
  4. Feb 17, 2022 at 6:00 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    It acts like it is low on fluid. The fluid has to be going somewhere. Get down there and take a peak
