'06 Six Speed MT Burning Oil Only in Reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco*Sauce06, Mar 17, 2021.
  1. Mar 17, 2021 at 8:49 AM
    Taco*Sauce06
    Taco*Sauce06 [OP] Well-Known Member
    `06 Tacoma 6-speed Manual Access Cab - White
    Nothing major. -3rd Gen OR suspension swap. -Trailer light plug relocation.
    I believe my '06 six speed is burning oil only in reverse. If I'm reversing gently it seems fine but if I give it a little gas I get a puff of blue(?)/white smoke (seems white but doesn't smell like burnt clutch. I've burnt the hell out of some clutches back in the day). I have not been able to "recreate" this in forward gears. I have approximately 137,xxx miles on it give or take about 1,000. I'll double check for a more exact number after work.
  2. Mar 17, 2021 at 9:08 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Ummm...... only the transmission reverses rotation of the drive shaft.
    The engine continues to rotate in it's normal direction.
    Is the exhaust emitting the blue/white smoke??
  3. Mar 17, 2021 at 9:20 AM
    Taco*Sauce06
    It's definitely a white-ish color, I'll double check this evening when I get off work to see if there's a blue tinge to it.
  4. Mar 17, 2021 at 10:10 AM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    Are you sure you just aren't driving away from the puff when going forward vs backing into it so you don't see it?
    blu92in99, tinker_troy and whatstcp like this.
  5. Mar 17, 2021 at 10:13 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Maybe if they drive in a circle?
    Hobbs and tinker_troy like this.
  6. Mar 17, 2021 at 10:14 AM
    rock headed
    rock headed Member
    Virginia
    06 TRD
    2 button Locker anytime. 400w anytime. 3rd Gen struts/shocks. AFE air intake. AFE cat headers and 3" cat back. Firestone airbags with cups. TPMS delete. 2 wheel low
    Your description suggests you are seeing engine smoke when you back up. Gear oil in the manual transmission has no way into the engine.
  7. Mar 17, 2021 at 10:14 AM
    Taco*Sauce06
    Yeah I'm sure I'm not driving away from it when going forwards. For the amount of smoke that's coming out I'd definitely be able to see it in my mirrors.
