06 Taco Timing Chain?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bradpace16, Jan 17, 2013.
  1. Jan 17, 2013 at 8:19 AM
    bradpace16
    bradpace16 [OP] Active Member
    Denver, CO
    06 Tacoma Crew
    I have heard 05 and newer 4.0 V-6 Tacos have chains? If so, when do you guys recommend a replacement?
  2. Jan 17, 2013 at 8:21 AM
    ORTACO
    ORTACO Member
    06 Tacoma 4x4 TRD Offroad
    none yet
    If it aint broke dont fix it.
  3. Jan 17, 2013 at 8:24 AM
    bradpace16
    Denver, CO
    06 Tacoma Crew
    If it breaks, won't I screw up tons of stuff? Like timing and everything else?
  4. Jan 17, 2013 at 9:25 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    It won't break unless you run engine with no oil, but even then more likely will just stretch.
    So chain replacement is pretty much never. Chain guides are maybe a different story but unless you using junk oil and constantly rev up engine you should not hear them before 200k miles.
    In essence .... find something else to worry about because this is pretty much maintenance free item. :D
  5. Jan 17, 2013 at 10:08 AM
    bradpace16
    Denver, CO
    06 Tacoma Crew
    Thank you for the response.
  6. Jan 17, 2013 at 10:24 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    The old Toyota vehicles that had a band needed to be replaced every 80K or so. I wouldn't worry about the chain.
    BTW, if the chain did break, you would have a lot more than the timing to worry about. Pistons hitting valves that are in the wrong place because the cam isn't moving would make for a new engine, or at least a rebuilt one.
  7. Jan 17, 2013 at 3:46 PM
    bradpace16
    Denver, CO
    06 Tacoma Crew
    Okay great, so what would you say to the advice of don't fix the chain until it breaks? And how many miles should I think about changing it out?
  8. Jan 17, 2013 at 4:01 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Not true, the Toyota 1gr-fe engine is of a non-interference design...
