'06 Tacoma 2.7 Standard Towing a '13 Polaris 850xp ATV?
Discussion in 'Towing' started by Mrhiker101, Jul 29, 2013.
  1. Jul 29, 2013 at 5:42 AM
    Mrhiker101
    Mrhiker101 [OP] New Member
    NC
    06 Tacoma 4cyl.
    Hello all,
    I have a 2006 Tacoma 2.7 2wd standard and I'm looking at getting a trailer to tow a 2013 Polaris 850xp LE. Should I have any issues with the truck pulling a small 4"x6" or 5"x7" trailer with the ATV on it? I expect to have a loss in power but I do not want to put too much strain on my transmission. The dry weight on the Polaris is 773 lbs. and all I want is a trailer big enough to tow it and nothing else. I had been putting the ATV in the bed however, since adding a front brush guard I'm afraid it's just too long to put in the bed. Before I had to ride with the tailgate down as it was which was no big deal but now I don't want to take the chance of knocking my rear window out when I'm loading it up. I watched my father do that several years back with his ATV in his truck. I just feel it's safer if I have a trailer. Any help is appreciated. Thanks and I hope everyone has a safe week.
  2. Jul 31, 2013 at 11:14 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    You will be fine. Make sure you strap everything down well.
    Truck shouldn't even break a sweat. I have the V6 and tow my double jetski trailer...I can barely even tell its back there.i wanna say those are like 900lbs a piece...
  3. Jul 31, 2013 at 11:17 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    you will have no problem at all. i haul my two grizzly 660 atvs up the donner summit in a enclosed trail with my little four banger and it does it no problem
  4. Aug 5, 2013 at 10:50 AM
    taco206
    taco206 Well-Known Member
    You'll be fine. I tow alot more on my 4 cylinder 5 speed. The longest towing trip I have done on the 4 cylinder is from Seattle to Spokane with my old 4.5 by 8 by 2 utility trailer. It was a home made really heavy trailer about 900 pounds with some furniture inside. Real wood type stuff, maybe 500-600 pounds in there and some crap in the bed. It was a fairly smooth trip, made it there and back, but the gas mileage was way down (it WILL break a sweat). Not terrible MPG, but not as good as a V6 would get.
    Pull the trigger, get a nice trailer, they're good investments and you'll be alot safer.
  5. Aug 5, 2013 at 11:00 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    The 2.7 is a strong motor for its size, with good torque. I don't know how your diff is geared (mine was nice and high, I believe 4.87s) so first gear was useless until I put on 33's. That said, if you are geared well you won't stress your tranny pulling the extra weight. Loading and unloading out of a trailer will be way easier, and will save you a ton of wear and tear on the bed of the truck. I crumpled a tailgate unloading a slab of granite. Smart move OP!
  6. Aug 7, 2013 at 1:49 PM
    4bangeronabudget
    4bangeronabudget Well-Known Member
    Maine
    08 2.7l base
    Blacked out badges Tough country lift Scs stealth 6 wheels LEDs Warn transformer w/ light bar winch mount Volant ram air intake Reese hitch Timbrens 5100s Warn 9500 winch Skids
    Your good man that sled probly weighs less than 700 pounds. For comparison i have towed over 2000lbs with mine ( pretty much stock motor) just keep in mind the smaller the trailer the harder it is to back up. And you have 4.10 gears by the way same as mine.
