'06 Tacoma Gas Mileage Suffering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snpower, Feb 21, 2011.
  1. Feb 21, 2011 at 3:19 PM
    snpower
    snpower [OP] Member
    Central Virginia
    06 Tacoma SR5 Double Cab
    Greetings -
    First post here despite having owned my truck since new. Why? Because I've never had a problem with it! :D
    The gas mileage is... down. I've always gotten right around 18 and 22 day in and day out. City is now down to just under 16. Highway is down to 20-21. The truck has 43K, a K&N filter, Cooper Discoverer tires. I burn 89 octane per the manufacturer's recommendation. Not sure what to think other than crappy winder blends of fuel but I'd like to hear ideas (I did recently service the filter). The truck has the oil changed every 4K and the tires rotated/checked every 5K. A cat. converter problem? I hope not...
  2. Feb 21, 2011 at 3:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    How about spark plugs?? When is the last time those were changed out. And how many miles do you have??
  3. Feb 21, 2011 at 4:40 PM
    snpower
    snpower [OP] Member
    Central Virginia
    43K original plugs. Seems early but definitely NOT a bad idea. What plug would/can you recommend?
  4. Feb 21, 2011 at 4:44 PM
    Hondarider08
    Hondarider08 "That's what she said..."
    Justin
    Logan, UT (Originally Pocatello, ID)
    05 Tacoma TRD
    Leveling kit, K&N drop in, and a Loud Ass Stereo :)
    Try cleaning your mass air flow sensor. especially with the drop in filter. that oil will soak through and coat the sensor and throw you milage off. just grab some electrical contact cleaner and then spray it down really good. It brought my milage back to normal after the slight drop.
  5. Feb 21, 2011 at 5:08 PM
    snpower
    snpower [OP] Member
    Central Virginia
    Excellent advice. I'll do the aforementioned and report back.
  6. Feb 21, 2011 at 6:33 PM
    Brunes
    Brunes abides.
    Rotorhead
    It might seem early on the plugs- but these are 30K plugs and are pretty sensative. I pulled mine at 35K and they were all out of spec...just a little bit- but a little bit matters on a plug.
    Hopefully those things will help you out!!
  7. Feb 22, 2011 at 1:01 PM
    snpower
    snpower [OP] Member
    Central Virginia
    OK. Plugs done. Mass Airflow Sensor done. Throttle body done. Great write ups on this site! Spent probably $36.00 on parts. Now we wait until I need more fuel.
    Funny –I have maintained two BMWs and done extensive work on each, and generally stay ahead of the curve. I ASSumed the dealer and the other shop I use were looking out for me.
    :D
  8. Feb 22, 2011 at 1:10 PM
    Brunes
    Brunes abides.
    Rotorhead
    They may not be...but we are!! Plus you spent a lot less this way.
  9. Feb 23, 2011 at 6:53 AM
    snpower
    snpower [OP] Member
    Central Virginia
    And there I was, feeling good about doing 2 out of the 3 mentioned maintenance items. I'll hit the LSD fluid next payday, and dump in the injector cleaner ASAP.
  10. Feb 23, 2011 at 7:54 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Something that rarely get's mentioned,,, but mpg problems can also be caused by the O2 sensors starting to go. Downside is you never know which one(s) it might be unless they fail completely and throw a code, and the price to replace 'em all is nasty.
    But if you do everthing else and still no success, might want to consider this.
  11. Feb 25, 2011 at 2:29 PM
    snpower
    snpower [OP] Member
    Central Virginia
    Checked the mileage today @ fill-up. It's BACK UP. I only burned 1/2 tank since the tune up but I calculated it as 17.19 mpg (city driving only).
