06 tacoma hub torque
Discussion in 'Wheels & Tires' started by ToyoTaco06, Apr 1, 2011.
  1. Apr 1, 2011 at 7:01 PM
    ToyoTaco06
    ToyoTaco06 [OP] Active Member
    BC
    06 Tacoma SR5 Short box
    6" Lift, 35's
    can't seem to find a hub nut torque spec for a 06 tacoma 4x4. much help appreciated.
  2. Apr 1, 2011 at 7:18 PM
    tinker_troy
    tinker_troy VAN ENTHUSIAST
    WA
    Blue Subaru Thingamagigy
    I think it's 175 foot pounds... let me double check.
  3. Apr 1, 2011 at 7:32 PM
    tinker_troy
    WA
  4. Apr 1, 2011 at 8:45 PM
    ToyoTaco06
    BC
    6" Lift, 35's
    i assume drive nut, (sucks cv through back of bearing) and also the hub with the lugs on it, how does that come out of the bearing?
  5. Apr 1, 2011 at 8:46 PM
    tinker_troy
    WA
    Press.
    Best bet is to take it somewhere and have them press the old ones out and new ones in. Unless you have a press and even then it sucks.
  6. Apr 1, 2011 at 8:50 PM
    tinker_troy
    WA
  7. Apr 1, 2011 at 8:57 PM
    ToyoTaco06
    BC
    6" Lift, 35's
    i can't even get the bearing off without getting the f*ckin hub off first, nevermind a press to push it out! the 4 bolts loosen off but can't fully come out due to hub.
  8. Apr 1, 2011 at 9:00 PM
    tinker_troy
    WA
    you might have to use a bearing puller to get the hub/bearing assembly to pop off once you get the bolts loose.
  9. Apr 1, 2011 at 9:12 PM
    tinker_troy
    WA
  10. Apr 2, 2011 at 2:55 PM
    ToyoTaco06
    BC
    6" Lift, 35's
    sorry i posted before i read that article, (my bad), bearings are off and in the shop getting hubs swapped over, thnx for the information very much appreciate it.
  11. Apr 2, 2011 at 3:12 PM
    tinker_troy
    WA
    I feel your pain man. I did them a few months ago and it's a motherf**ker.
  12. May 17, 2011 at 5:06 PM
    eyball
    eyball Well-Known Member
    Quinebaug, CT
    05 Double Cab SR5 V6
    Extang Tri-Fecta Tonneau cover, Westin nerf bars, K&N intake, OEM roof rack.
    Toyotaco06, any tips on doing the bearing swap? I am getting ready to do both in my 05 4wd. Thanks!
