06 Tacoma Misfires...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rasta_yute, Mar 4, 2008.
  1. Mar 4, 2008 at 7:31 PM
    rasta_yute
    rasta_yute [OP] Member
    a couple days back, i've noticed a series of misfires, and intermitent sputtering. what are the possible causes of this mystery problem?
  2. Mar 4, 2008 at 7:32 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    do you have any modifications?
  3. Mar 4, 2008 at 7:34 PM
    rasta_yute
    nope, bone stock...
  4. Mar 4, 2008 at 7:35 PM
    rasta_yute
    okay, its an 06, 4.0l engine, daily driver, most noticable while accelerating...
  5. Mar 4, 2008 at 7:36 PM
    rasta_yute
    there are no extremes as it relates to temperature. the climate is tropical (jamaican climate)
  6. Mar 4, 2008 at 7:38 PM
    06tacoma
    06tacoma Well-Known Member
    Tampa FL
    06 PreRunner SR5 XS-P Trd Longbed Double Cab
    20" enkei wheel,BFG G-Force tires, BHLM, Smoked tail lights, 2 RE Audio 10s, Quantom 900watt amp,10000K HIDs headlights and fog lamps,Borla exhaust, Borla drop in filter,Debadged tailgate,Painted black tacoma badges
    sounds like some old spark plugs
  7. Mar 4, 2008 at 7:40 PM
    rasta_yute
    could tainted petrol be a factor? noticed this sputtering after a precarious fill up...
  8. Mar 4, 2008 at 7:46 PM
    rasta_yute
    can't be more than 600 miles or so
  9. Mar 4, 2008 at 7:47 PM
    utixrunner
    utixrunner I <3 Boost
    Florida
    2007 SWB X-Runner
    TRD S/C, DT Long Tube Headers, Jardine Catback, TRD Intake, Trd Short shifter, TTC Dual Traction Bars, Sway bar bushing kit, c2c lowering kit, lots of other little things
    600 miles? where did you get your plugs? where they gapped properly?
  10. Mar 4, 2008 at 7:49 PM
    rasta_yute
    gotten from the dealership...
  11. Mar 4, 2008 at 7:54 PM
    rasta_yute
    work also done by dealers...
  12. Mar 4, 2008 at 7:57 PM
    06tacoma
    Tampa FL
    you might want to have the dealership take a look at spark plugs could have been gapped wrong also you injectors might need to be cleaned
  13. Mar 4, 2008 at 8:02 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Throw us a bone here.
    How many miles on the rig?
    Last maintenance done? Include all services done.
    Check engine Light on? If so the code.
    I can't really help you until we know these things.
  14. Mar 5, 2008 at 7:36 AM
    rasta_yute
    okay, its got little under 50 thousand miles on it. and yes, the check engine light has appeared...
  15. Mar 5, 2008 at 1:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    get the code read and let us know what it says.
  16. Mar 5, 2008 at 5:23 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Check engine light is a good start. Def let us know what the code is.
    My guess is with new spark plugs they may not be gapped properly or are not the correct ones that are needed for the engine. Of course I could be wrong.
  17. Mar 5, 2008 at 6:44 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    My car did that when it sucked water in the intake. At least that's what I assume. Only happened when it rained and I drove through even the slightest amount of standing water. I had a short ram intake on it, and could duplicate the symptom when I poured Seafoam cleaner into the intake while the engine was running. I switched back to the stock intake and the problem disappeared. Until my wife went to go to school after it had been very humid for a few days and the car hadn't been driven. She drove to 2 miles or so back, and when I took it back out right after that it ran fine.
    So maybe make sure the intake is dry. My CEL came on during that as well. It flashed while the engine was stuttering, and went off when I drove it (and the engine ran fine). It also came on every time before when it stuttered in the rain/standing water. Not sure what the code was though as the light never stayed on long enough to read it.
  18. Mar 5, 2008 at 6:53 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I just had another thought.
    Did this start happening right after the plugs were replaced?
    If so check the electrical connections on the coil packs.
  19. Mar 5, 2008 at 6:55 PM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    You got an ignition problem. Check the coil pack, plug wires, plug gap. Make sure the plugs are torqued correctly. Make sure there are no hairline cracks in the coil packs. Condensation can collect and cause a misfire. Sounds like the $tealer fucked up your ride dude.
