06 tacoma TRD sport automatic trans issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CanadianTaco98, Jan 29, 2021.
  1. Jan 29, 2021 at 3:36 AM
    CanadianTaco98
    CanadianTaco98 [OP] Active Member
    Colin
    2021 TRD Sport, 2006 TRD Sport
    Can manually shift it into D and 4, but i cant move the shifter into 3 or 2L?
  2. Jan 29, 2021 at 5:43 AM
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    maybe pull the console cover and check the shifter mech, something must be binding, or maybe at transmission cable end there is mud/dirt build up not allowing full range of motion
    CanadianTaco98[OP] likes this.
  3. Jan 29, 2021 at 7:06 PM
    szydlo
    szydlo Member
    David
    Western NY
    05 access cab TRD Sport package & 2020 Tacoma dbl cab Black TRD Off-Road
    2005 stock, brush guard, tube steps, color matched ARE bed cap 2020 Tacoma, SS tube steps, block heater Gator ETX soft tri-fold bed cover added new LED bed lights, Scan gauge
    You may need a new neutral safety switch. Mine corroded and made it hard to shift a few years ago. Check on the right side of the transmission case (passenger side). [​IMG]Spray it around the nut in the middle and try shifting it between park an 1st and see if you gain travel. if so pick one up on Ebay.(around 23-70 bucks) Don't try to remove it unless you have a replacement ready. It might fall apart when removing and put your truck on the sidelines until you get a new part.
    Good luck,
    Dave
    Too Stroked likes this.
  4. Jan 30, 2021 at 7:07 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    FWIW.....
    Common references:
    Right side = Passenger Side
    Left side = Driver Side.
