06 v6 front passenger side squeal goes away when brakes applied
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VikingTrad3r, Jun 29, 2017.
  1. Jun 29, 2017 at 6:39 PM
    VikingTrad3r
    VikingTrad3r [OP] Well-Known Member
    "contractor model" white with black fenders
    hi. 2006 v6 4x4 167000 miles
    squeaking "eek eek eek" front passenger side unless brakes are applied.
    engaging 4x4 doesnt change it so i dont think its cv or front diff needle bearing related.
    i took off the wheel spped sensor and put in 30 pumps of grease (something ive learned prolongs non-serviceable wheel bearings as an access point for greasing bearings and no the grease doesnt affect the magnet) with zero change so i dont think its wheel bearing related plus there is no movement in the wheel while raised in the air.
    that leaves the wear indicator tang on the pads but they have 80% on them.
    the closest thing ive read to my situation and the fix is on gbe forunner forum and it was a sticking caliper piston not retracting.
    here is thread: do we have any precident in our tacos for this?
  2. Jun 29, 2017 at 7:45 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Warped rotar? Had that on a 2008 Ranger. Turning them fixed it. But it was so bad that i could feel the brake pedal modulate. If a high spot on the pads, try slamming on the brakes hard, very hard a few times at around 60 mph
  3. Jun 29, 2017 at 7:49 PM
    VikingTrad3r
    I get no movement or pulsing on breaking hard or soft from fast or slow. Brakes function perfectly.
    I should probably pull the pads off and do an inspection. It might be obvious after that
  4. Jun 29, 2017 at 7:53 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    Maybe brake dust. What if u wash the area then drive see if it goes away. They do make brakes that gives little to no brake dust.
  5. Jun 29, 2017 at 7:55 PM
    iLLogics
    iLLogics Well-Known Member
    Eastvale Ca.
    2007 Access Cab OR
    I'd clean the pins that attach the brake pads to the caliper first. You could have mud, sand, brake dust, rust, or even a small little pebble hiding between the caliper, pad and pins. Just enough junk to make the pad sit against the rotor lightly and cause the squealing. Might sound stupid but it's the first place id look.
  6. Jun 29, 2017 at 7:56 PM
    Braves95
    David
    Central PA
    Or the sliders might be sticking. May need to remove them add astro glide, to allow them to slide better.
    iLLogics likes this.
  7. Jun 29, 2017 at 7:59 PM
    VikingTrad3r
    thnx all. just licked a tub of the synthetic brake grease and will pull pins and inspect all components.
    Braves95 likes this.
  8. Jun 29, 2017 at 7:59 PM
    VikingTrad3r
    i also "picked" it up after licking it. lol.
    stickyTaco, iLLogics and Braves95 like this.
  9. Jun 29, 2017 at 8:03 PM
    Braves95
    David
    Central PA
    Let us know how it turns out.
  10. Jun 29, 2017 at 8:03 PM
    iLLogics
    Eastvale Ca.
    2007 Access Cab OR
    5 second rule
  11. Jun 29, 2017 at 8:22 PM
    VikingTrad3r
    does it matter if im missing the brake pad retainer clip?
    i am.
  12. Jun 29, 2017 at 8:25 PM
    VikingTrad3r
    and the slider pins are completely corroded and rusted so I can't see how anything is sliding on it. I have to hammer at it to get it out
  13. Jun 29, 2017 at 8:54 PM
    iLLogics
    Eastvale Ca.
    2007 Access Cab OR
    Spray some pb blaster, liquid wrench or wd40 on them and let them soak a bit before giving them the hammer. You just need something to help break up the crud.
  14. Jun 29, 2017 at 10:06 PM
    VikingTrad3r
    got them off, missing the top "spreader" spring and the retainer clip thingy. the bottom "spreader" spring was present.
    the entire setup was corroded really bad.
    i cleaned it up and ran the slider pins under the bench grinder with the brass brush on it. took all the corrosion off.
    had cotter pins in my grandfathers old parts case!
    squeek squeek squeek is gone!
    ill see if i can find a "spreader" spring somewhere. (?)
  15. Jun 29, 2017 at 10:21 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    There are no "sliders" in this case. It's a fixed four piston caliper.
