06 water bypass pipe.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoEd76, Mar 4, 2016.
  1. Mar 4, 2016 at 4:07 PM
    TacoEd76
    TacoEd76 [OP] Member
    06 2.7 4x4 175k
    image.jpg image.jpg Just got back from the dealership. I had originally bought a water bypass pipe to replace the broken part on my Tacoma. Why the manufacturer would use harden plastic is beyond me but it is a good vehicle. Replacement part is made of stainless steel. I did not know that it required a gasket for the new style flange. Just got a call back and said that they will have my car until Tuesday. That is four days from now. Is this normal to wait so long to get a gasket shipped to them?
  2. Mar 4, 2016 at 4:32 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Do you have part numbers ? Where is this pipe ? Thinking it might be good preventative maintenance. Thanks for any reply.
  3. Mar 4, 2016 at 5:59 PM
    TacoEd76
    06 2.7 4x4 175k
    16268-75110. Left side of engine block. Runs under intake manifold from front to rear. 05'-15'. Standard problem
  4. Mar 4, 2016 at 6:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    Does it take an actual gasket in the 'traditional' style?
    Or an o-ring seated in a groove?
  5. Mar 4, 2016 at 6:25 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Nice stainless replacement. No idea why it is, but I want one.
  6. Mar 4, 2016 at 6:54 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    4 cyl. only
  7. Mar 4, 2016 at 7:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My 2012 came with the stainless steel bypass pipe. The intake has to come off to replace it.
  8. Mar 5, 2016 at 5:28 AM
    george3
    New Jersey
    Thanks for the reply and information - does the part number 16268-75110 come with the gasket or is that a separate part number ? I googled 16268-75110 and it looks like about $38 plus shipping - didn't check shipping charges yet. Thanks again.
  9. Mar 5, 2016 at 6:50 PM
    TacoEd76
    06 2.7 4x4 175k
    Oring in seated groove.
  10. Sep 8, 2021 at 11:57 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The original plastic bypass pipe has an O-ring in the flange. The upgraded metal bypass pipe has a flat gasket that covers the whole flange surface on the front side of the pipe. The gasket is sold separately. The inner raised surface of the gasket goes toward the block/thermostat housing, it should nestle into the recessed area where the original O-ring used to be. Torque the nuts to 13 ft-lb.
