06 X-Runner 4.0 RWD - RA60 transmission stuck in reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaoster, Mar 7, 2025.
  1. Mar 7, 2025 at 7:45 PM
    Khaoster
    Khaoster [OP] New Member
    Hello, I have a problem where I went to reverse and then try to shift into first. It somehow got stuck in reverse gear but shifter is in the neutral position. I can’t shift into anything currently and it’s stuck in reverse.
    SOLVED solution below
  2. Mar 8, 2025 at 6:53 AM
    Waasheem
    Waasheem
    2007 xrunner
    The lever has a rubber epoxy inside to reduce vibration. It’s common for the rubber to deteriorate causing some slop. Has the lever felt sloppy and vague lately?
  3. Mar 8, 2025 at 7:13 AM
    Toyko Joe
    Toyko Joe Here for the pictures
  4. Mar 8, 2025 at 7:18 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  5. Mar 8, 2025 at 6:09 PM
    Khaoster
    *SOLUTION FOUND* ANSWER BELOW ⬇️ ⬇️ ⬇️
    Hey guys found the solution, take off the reverse switch grab a mirror if the reverse indicator is directly in the middle of the hole grab a flathead screw driver, put it on the left side of the lever and pry forward to get it off center and back into neutral position. Then you should hear a click when in neutral and put reverse switch back on. Then check the shifter if it goes in all the gears and my did.
    once I did that, I was able to go thru all 6 gears with no issues and reverse. I have a short shifter as well. I have rebuilt the shifter 2 years ago and bushing looks great still.
    tinker_troy and deanosaurus like this.
  6. Mar 8, 2025 at 6:13 PM
    Khaoster
    Also thank you for everyone trying to help! Appreciate your guys time
    tinker_troy likes this.
