07 2wd 4 cyl melted transmission plastic thingy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jburt, Oct 23, 2017.
  1. Oct 23, 2017 at 5:18 PM
    jburt
    jburt [OP] Member
    Jeff
    Imperial County, CA
    97 4Runner
    2.5" Kings, E-Locker, 231mm TBU, 220K, B&M 70264, Duratracs, MStudt RLCA's, Shrockworks skids, and some other stuff
    So I was helping a buddy with this 07 today. He thought his clutch was gone, but something else seems to be wrong. He was driving home and he felt a big bang and lost all power.
    I climbed under his truck and this is what I saw on some kind of plastic inspection plate for the trans:
    [​IMG]IMAG1424 by Jeff Burt, on Flickr
    With the truck in 1st gear you can easily push it in reverse. When you push it forward it feels like the trans is grinding, but it still moves pretty easy
    Thoughts?
  2. Oct 23, 2017 at 5:19 PM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
  3. Oct 23, 2017 at 5:33 PM
    jburt
    jburt [OP] Member
    Jeff
    Imperial County, CA
    97 4Runner
    Fixed it. Still getting used to flickr after photobucket crapped out.
  4. Oct 23, 2017 at 6:03 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Smoked the clutch disc right down to the metal backing plate, likely bad pressure plate and it's been slipping so bad it heated up the housing. It should have been VERY noticeable to pretty much anyone with just a bit of time in a manual transmission vehicle. Flywheel is roached also.
    SOSC likes this.
  5. Oct 24, 2017 at 6:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Shiiiiiiiit! That seems to have heated up rather hot.
    Hopefully it is just the pressure plate, clutch, throw out bearing and fly wheel. I would also drain the tranny and refill it with fresh oil as it probably got quite hot also.
    SOSC likes this.
  6. Oct 24, 2017 at 6:47 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    I doubt there wasnt any other signs before that happened.
    Toyko Joe and SOSC like this.
  7. Oct 25, 2017 at 7:29 AM
    jburt
    jburt [OP] Member
    Jeff
    Imperial County, CA
    97 4Runner
    Thanks guys. I'll pass that along. I'm not sure if he noticed any other symptoms but I'll check.
  8. Oct 25, 2017 at 11:39 AM
    lifewithoutparole
    lifewithoutparole Well-Known Member
    Tim
    Ormond Beach Florida
    2007 Tacoma 4WD
    Mine is a 2007 4 cyl. 4WD and has 137K on the original clutch. Doesn't slip at all. I was just out west for a long trip and it did fine in the mountains.
  9. Oct 25, 2017 at 1:12 PM
    jburt
    jburt [OP] Member
    Jeff
    Imperial County, CA
    97 4Runner
    I talked to him today and he said that he did notice it slipping a lot. Oh well. It's his first stick.
    I told him we could pull it apart and replace whatever was broken, but I'm pretty slow with projects. Being in college he just wants to get it done.
    We're pretty close to mexico and I think he's just going to look for a used tranny and put a new clutch into that. I'll update this if anything interesting happens.
  10. Oct 25, 2017 at 2:11 PM
    67 Series IIA
    67 Series IIA Active Member
    Ed
    Green Harbor, MA
    08 4X4
    Bed Tie down's, Heated Mirrors, HD radio, Wet Okley seat covers, Intermittent wipers, side rails, tailgate cap.
    2008 Reg cab 4WD 221,000mi on the original clutch and no slip yet.
    Of course I just jinxed myself.
  11. Oct 25, 2017 at 2:18 PM
    jburt
    jburt [OP] Member
    Jeff
    Imperial County, CA
    97 4Runner
