07 4x4 help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Apollo, Dec 29, 2009.
  1. Dec 29, 2009 at 11:56 AM
    Apollo
    Apollo [OP] New Member
    Hey everyone-
    I need some help guys. My truck is dire need of aid and im between a rock and a hard place. Long story-short version-
    The marriage went south, wife and new hubby beat the crap out of the truck, broke/damaged multiple things and now I have regained custody but my truck needs some serious help.
    -All dash lights come on when the truck runs. SRS, check engine, 4x4 oil. the whole damn thing.
    -4x4 does not work and 4x4 light is blinking
    -truck will not run on the first start no matter what. It starts but dies immediately. Always starts and idles on the second attempt though.
    -it will not rev past 3k and when i attempt to accelerate, the truck down shifts but bogs down. Feels like no power and as soon as i let off the gas she evens out. Its not like i cant get up0 to freeway speed but she just doesnt rev
    Those are the most pressing issues. There is a slew of things wrong but it seems like these are the most important to fix right now. Any help would be greatly appreciated.
    2007 Tacoma crew cab 4x4
  2. Dec 29, 2009 at 12:05 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Wow, I feel for ya man. Sounds like the truck was beat up pretty good and neglected. Hope someone here can get you pointed in the right direction.
  3. Dec 29, 2009 at 12:07 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I had a truck that had a clogged cat that would not rev past 4k. You might want to check on that. It could also be the reason why it would not idle at first start since it can't get any exhaust out. Also check the maf sensor for any clogging and the air filter also.
    4x4 - could be as simple as a switch or a module not engaging.
  4. Dec 29, 2009 at 12:07 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    that sucks man.check under the hood.look for anything that might of been disturbed, the air cleaner.almost sounds like they had it in deep water/mud. maybe a clogged cat.hard to say what they did to it.
  5. Dec 29, 2009 at 12:08 PM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    how many miles, and welcome to tacoma world
  6. Dec 29, 2009 at 12:08 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights
    Sorry man, that sounds horrible. I can't help ya out but I hope it all works out for you.
  7. Dec 29, 2009 at 12:25 PM
    DriverSound
    SoCaca
    Too few to list.
    I wonder though, did they screw up the truck because they knew you were going to get it back or did they just screw it up to begin with?
    You should also check your gas if the first one is the case. Check for anything unplugged or cut wiring.
  8. Dec 29, 2009 at 12:44 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    thats a great question.
  9. Dec 29, 2009 at 12:54 PM
    Apollo
    Well im very capable mechanically but i just need a lead first. I dont have a scanner to read the computer codes so its just up to my best guess and obvious symptoms to find out what the deal is.
    The truck has just a little over 60k on the odometer. I agree, its gotta have something to do with the MAF because I can definitely smell gas in the exhaust. But it runs just fine otherwise. Its only under load that the truck struggles to keep the revs up.
    I'll check the cat and a few other things because im almost positive they took it through multiple mud bathes and water crossings, but is there a tell-tale sign or area i can look to or photograph for you guys to help? Vid of it running?
    Thanks guys
    the truck as she sits now
  10. Dec 29, 2009 at 1:12 PM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Ahh the multiple mud baths might indicate the alternator is not outputting properly. Check your voltage with a meter.
  11. Dec 29, 2009 at 3:38 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Check voltages, check inside your air box for signs of water or mud.
    If your 4x4 is blinking, maybe the wires underneath were disconnected/torn from the transfer case actuator. Have you looked underneath the truck to inspect the wiring?
    This could also be intentional and her new idiot simply unplugged some wiring connections, cut some wires, etc. Check connections to see if all is well. Check the fuse panel to see if any fuses have been blown/removed.
    When you say the truck has been beat up, do you mean cosmetic trail damage or they literally and purposely caused damage to the truck?
    You say you recently regained custody of your truck. Did a judge decide this? Was it your all along and they just joy-rided it? Sue them for damages and have them pay for ALL the repairs.
    Have the CE light scanned at a local auto parts store or independent shop to see what codes are being communicated.
  12. Dec 29, 2009 at 3:42 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    im not expert so im just gonna come along for the ride...
    :popcorn:
  13. Dec 29, 2009 at 7:00 PM
    Apollo
    -Voltage checked out fine
    -Newish air filter wish no abnormal signs of wear
    -As for the 4x4, I havent gotten under the truck to give it a thorough checkup but I think the problem is a damaged or non existant connection. Its all kinds of screwed up. It feels like the rear locks up or is constantly locked because the tires will hop big time when turning just even 75%
    -Im sure the truck endured all kinds of punishment. Malicious or not, the truck has mechanical, cosmetic and serious interior damage.
    -It would be nice if we lived in a world where it was as easy as suing but these people now live off the grid in a, nomadic, loser-ish kind of way. Dont even know where they are or when i will hear from her next. I had to go up to her property to take the truck back when i heard she hadnt been living there for a while.
    -My buddy is going to come by with a scanner later this month so im crossing my fingers, hoping for the best and expecting the worst. . .
  14. Dec 29, 2009 at 7:08 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    o2 sensor, maf sensor, disconnected wires to transfercase/tranny, these are a few of my unfavorite things.
    almost like a song huh?
    but really these would be a good starting point.
  15. Dec 29, 2009 at 7:17 PM
    07trd4x4
    07trd4x4 Well-Known Member
    Greg
    Truckee/Sacramento CA
    LX570
    Sorry bro. Wished you were closer I would try and help you out!!!!
