07 4X4 Recall???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gerry Pope, Nov 14, 2008.
  1. Nov 14, 2008 at 10:09 PM
    Gerry Pope
    Gerry Pope [OP] Well-Known Member
    San Diego
    07 4X4 PreRunner
    Got this from my local dealer..
    Anyone here been notified of this?
    ON CERTAIN PICKUP TRUCKS EQUIPPED WITH FOUR WHEEL DRIVE, A SECTION OF THE REAR PROPELLER SHAFT MAY HAVE BEEN IMPROPERLY CAST. THE FRONT SIDE OF THE REAR PROPELLER SHAFT COULD SEPARATE AT THE JOINT AND COME INTO CONTACT WITH THE ROAD SURFACE WHICH COULD RESULT IN A LOSS OF VEHICLE CONTROL, INCREASING THE POSSIBILITY OF A CRASH. DEALERS WILL REPLACE THE REAR PROPELLER SHAFT WITH A NEW ONE FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 1, 2007. OWNERS MAY CONTACT TOYOTA AT 1-800-331-4331. TOYOTA RECALL NO. 70D.OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
  2. Nov 14, 2008 at 10:21 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Thats crazy.
  3. Nov 14, 2008 at 10:34 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    There's one on the Tundra have not seen a resent one on the tacoma.
    I found this on the web
    Drive Train: POWER TRAIN DRIVELINE
    Campaign Number: 07V324000
    Dates Manufactured: 05/2007 to 06/2007
    Number of Vehicles Affected: 108
    Model Years Affected: 2007
    Date Owner Notified: 08/2007
    Defect Summary: ON CERTAIN PICKUP TRUCKS EQUIPPED WITH FOUR WHEEL DRIVE, A SECTION OF THE REAR PROPELLER SHAFT MAY HAVE BEEN IMPROPERLY CAST.
    Consequence Summary: THE FRONT SIDE OF THE REAR PROPELLER SHAFT COULD SEPARATE AT THE JOINT AND COME INTO CONTACT WITH THE ROAD SURFACE WHICH COULD RESULT IN A LOSS OF VEHICLE CONTROL, INCREASING THE POSSIBILITY OF A CRASH.
    Corrective Summary: DEALERS WILL REPLACE THE REAR PROPELLER SHAFT WITH A NEW ONE FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 1, 2007. OWNERS MAY CONTACT TOYOTA AT 1-800-331-4331.
    Recall Notes: TOYOTA RECALL NO. 70D.OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
  4. Nov 15, 2008 at 12:05 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I got that for my truck last year about 1-2 months after I bought it, called a #, they check they last series of digits on the VIN and tell you if your veh is affected. Mine was not included on the recall and there are only 108 trucks actually affected.
    The vehicles affected were manufactured between 5/30/07 through 6/4/07
    Vin #'s between
    VDS VIS
    LU42N 7Z439687 – 7Z442120
    MU52N 7Z439951 – 7Z442144
    PX42N 7Z441336 – 7Z441486
    UU42N 7Z440136 – 7Z442017
    UX42N 7Z439909 – 7Z442216
  5. Nov 15, 2008 at 4:54 PM
    Gerry Pope
    San Diego
    07 4X4 PreRunner
    Thanks for the Info..
  6. Nov 15, 2008 at 5:24 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I'll be checking this out when I get back on land somtime near thanksgiving hopefully. Thanks.
