07 Auto Trans Not Shifting Smoothly 4th>5th
Discussion in 'Technical Chat' started by jds0912, Jan 23, 2013.
  1. Jan 23, 2013 at 6:10 AM
    jds0912
    jds0912 [OP] Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    Hello there. I have had my 07 TRD OR for a few years now and noticed a problem shifting about 9 months ago and it is getting worse. I find that when shifting from 4th to 5th (auto trans) the truck seems to hang out in 4th gear until around 2500+ RPM before reluctantly dropping into 5th. I found that if I knock the shifter to the left and then back into D it will immediately change gears. Problem happens mostly on slight inclines, like merging onto the highway, and getting into highway speeds. Seems to lessen after driving for a period of time.
    This problem is probably contributing to my bad gas mileage (275 mi/tank) and is potentially effected by some codes I've thrown for a little while as well. My check engine light came on not too long ago and when I ran the codes I got 1-2 bus 02 sensor problems. Since then I have cleaned the MAF and throttle body, changed the plugs and the battery, but still get the check engine light.
    Do you think that the 02 sensors are bad and are contributing to my shifting problems (trying to warm up the engine by staying in OD)? Or are the two problems unrelated. Either way, I'd love to figure this out soon. Thanks for reading through this.
    /disclaimer: I have not been as proactive about this as I should have been, and the problem is likely getting worse due to my negligence.
  2. Jan 23, 2013 at 6:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How many miles on the truck?
  3. Jan 23, 2013 at 6:24 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Lifted? Big tires? I've driven two tacomas with stock gears and 35s that don't like shifting into 5th unless on a flat road.
  4. Jan 23, 2013 at 6:35 AM
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    I have the exact same problem. I did a tranny flush at 60,000 but still have the issue.I can go over 3,000 rpm let off and still will not shift until I bounce back to 4th and then into overdrive. Shifts immediately. I thought I was the only one.
  5. Jan 23, 2013 at 11:07 AM
    jds0912
    Justin
    Baltimore, MD
    I have like 72K or something. Not many, definitely <80K
    Im have 5100's and 255/75 BFG muds. I'm pretty sure I had the problem though before I threw the bigger tires on, just not as bad. Seems to be getting worse as time goes on.
    Yeah dude. Exactly the same as me.
  6. Jan 23, 2013 at 11:16 AM
    jds0912
    Justin
    Baltimore, MD
    Doing a tranny flush was going to be my next step, guess it doesnt help though, eh? Do you flash any codes? Check engine?
  7. Jan 24, 2013 at 5:21 AM
    jds0912
    Justin
    Baltimore, MD
    Bumping with tits
  8. Jan 24, 2013 at 5:26 AM
    Alby9999
    Alby
    NNJ
    I have the ultra gauge and until last night(go figure) no codes. Last night I got a pending code P0705 which is Transmission range sensor. I cleared it and nothing since. I think this means a break in communications from the shifter to the TCU. But that is the first and only time I got that. It was also a pending code and did not turn on the CEL. It's about 5 degrees out so that may have something to do with the code. Like the OP, the longer you drive the less it happens.
    Weird.
  9. Jan 24, 2013 at 5:33 AM
    Alby9999
    Alby
    NNJ
    Nice bumps
  10. Jan 24, 2013 at 5:48 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I came here for the tits.
  11. Jan 24, 2013 at 8:05 AM
    BamaToy1997
    Bill
    Navarre, FL
    I'll help, but please provide a bit more details in your post. Engine model, transmission model, stock wheel and tires? stock gears? any performance mods? What are the CURRENT codes in the PCM?
  12. Jan 24, 2013 at 9:16 AM
    jds0912
    Justin
    Baltimore, MD
    It's a TRD, so it comes with the 4.0l engine, not sure about the trans (auto) in an earlier post I specified that I have bilstein 5100's and 255/75 tires; stock gears. Only perf mods are the magnaflow muffler. I'll run the codes again but I'm pretty sure was flashing P0130, P0133. I'll run them again this weekend. I dont have a guage, so I have to go to vato-zone.
  13. Jan 24, 2013 at 2:44 PM
    BamaToy1997
    Bill
    Navarre, FL
    OK. I will check back to see the codes for sure when you get back from Vato
  14. Jan 24, 2013 at 3:17 PM
    gearcruncher
    Canadain bumper technician
    Sounds to me like the issue is a valve hanging up in the valve body . The problem is temperature sensitive and diminishes as the transmission gets warmer .
    I would suspect a hung spool valve inside the valve body casting that eventually frees up as the alluminum warms up and expands allowing the spool valve stroke .
    http://www.gearsmagazine.com/view.ashx?article=88d3ea95-41d0-4675-96ac-5d863f9133d1
    When was your last transmission service ?
  15. Jan 24, 2013 at 3:54 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Did you change your tail lights recently ? I had one led bulb and mine did kind of the same thing
  16. Jan 25, 2013 at 5:18 AM
    BamaToy1997
    Bill
    Navarre, FL
    Your taillights caused your transmission to no shift properly?:confused:
  17. Jan 25, 2013 at 5:33 AM
    Alby9999
    Alby
    NNJ
    Not to hi jack the thread OP but I have the same year and model as the OP and the same problem. Had the tranny flushed about 2,000 miles ago and still have the issue. 61,000 on the truck now.
    3" FR lift-AAL
    CAI-Ram air
    285/75/R16 BFG KM2s
    Just one code but it was a pending that has not resurfaced P0705.
  18. Jan 25, 2013 at 6:21 AM
    bellassaiw10
    Currituck NC
    Yeah not sure why or it may have just been electronically not letting the transmission shift, it would go bout 800 rpms higher before shifting into 5th then usual
  19. Jan 25, 2013 at 8:17 PM
    BamaToy1997
    Bill
    Navarre, FL
    OK, sounds like you just have a strange truck. I can't see anything in the wiring system, fuses , or power/ground distribution that a bad tail light would have any effect on a transmission shifting....sounds like a gremlin you had there.
  20. Jan 28, 2013 at 1:37 PM
    bellassaiw10
    Currituck NC
    Pulled it all out it ended up being the stock wiring with leds in it so just replaced the sockets with led rated ones
