07 brakes shudder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CharlieX, Mar 8, 2009.
  1. Mar 8, 2009 at 8:44 PM
    CharlieX
    CharlieX [OP] Well-Known Member
    urg... on a quick trip from LA to Vegas I've developed a pretty wicked brake shudder at highway speeds.
    Anyone else? I've got about 21K miles on my Double Cab Pre-Runner.
  2. Mar 10, 2009 at 11:28 PM
    CharlieX
    yeah, i'll get the rotors looked at. i also have a very very slight shimmy above 75. need to get the tires balanced. No real substantial heavy braking or long distance.
    what makes me suspicious is that this problem seems to have creeped up 6 weeks since I had the suspension TSB done. they checked the brakes and gave me 60-70% remaining on the pads.... wonder if something got misaligned when they put it all back together.
  3. Mar 13, 2009 at 4:19 PM
    CharlieX
    they did. at least the paperwork says they did.
  4. Mar 13, 2009 at 4:23 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I was expecting the same thing when I got done offroading on the beach this weekend. From what I understand, brakes and sand dont mix, but so far so good:mudding:
  5. Mar 13, 2009 at 6:06 PM
    GASH
    GASH Well-Known Member
    Josh
    Albuqueruqe
    07 TRD 4x4 DC
    Fox 2.5" Remote Reservoir Coil-Overs, All Pro Expedition leafs with Fox adjustable shocks, Armor Tech Offroad Skids, NST Lite Weight Pulleys, WeatherTec Floor Liners, TRD CAI, Custom Decals, Wheelers Super Bumpstop
    I was going to post the same question today. Mine shudders only when I press the brakes.
    Should I just start with a balance and go from there?
  6. Mar 13, 2009 at 6:12 PM
    CharlieX
    as I understand: if it shudders ONLY when braking, then there's something wrong with the brakes (warped rotor for instance). If you tires were out of balance, you'd feel the shudder when driving, usually when you hit a certain speed
  7. Mar 14, 2009 at 5:07 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    sounds like maybe the lugs r not torqued right.uneven torque will cause a roter to warp.or they r over torqued.just my 2 cents
