07 FJ locking hubs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KTMCowboy, Jan 19, 2020.
  1. Jan 19, 2020 at 4:28 PM
    KTMCowboy
    KTMCowboy [OP] New Member
    Ken
    2007 FJ Cruiser
    Bumper, winch, skid plates ect.
    I have a 2007 FJ, and Im looking to do a locking hub conversion. Cant seem to find a kit, or parts. Any help would be a big help.
  2. Jan 19, 2020 at 4:30 PM
    Bishop84
    Bishop84 Well-Known Member
    Do you have a manual or automatic FJ?
    The manual is full time AWD and unlocking the front axles would be detrimental. The automatic has an automatic differential disconnect. Both render the hub lock obsolete.
    Muddinfun likes this.
  3. Jan 19, 2020 at 4:38 PM
    KTMCowboy
    Ken
    2007 FJ Cruiser
  4. Jan 19, 2020 at 4:42 PM
    Bishop84
    What are you hoping to achieve?
    Because the FJ manual is 100% 4x4 all the time, the front axles need to spin or the transfer case will be stressed to the rear bias.
    It's not like the old trucks where the front diff and axles would wear rapidly and kill fuel consumption.
    Besides, they don't exist. Only the 80's and some 90's trucks had conversion kits from full time or auto locking hubs to manual hubs.
  5. Jan 19, 2020 at 4:54 PM
    KTMCowboy
    Ken
    2007 FJ Cruiser
    The fuel mileage is horrible. I drive easy, I'm getting 13 mpg. My Ram Diesel, stepped up is getting 15 around town, 19 Highway.
  6. Jan 19, 2020 at 5:10 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    2007 runs on premium fuel only too right??? Sell it and buy a different vehicle or buy a Civic to commute in. You aren’t going to make a 13 year old 4WD Vehicle get good gas mileage it’s a lost cause.
    Mully likes this.
  7. Jan 19, 2020 at 5:15 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    seriously you’re better off getting something else, although if you wanted to go the part-time 4x4 route you’d need about $500 in parts for the front diff and a j shift tcase from another fj or t4r.
    Mully likes this.
  8. Jan 19, 2020 at 8:12 PM
    KTMCowboy
    Ken
    2007 FJ Cruiser
    What parts would I need, and what transfer case?
  9. Jan 19, 2020 at 8:31 PM
    bijick
    E
    Stl
    theres a write up on here with the parts list, I’ll look through my saved real quick.
    for the tcase you just need any manual shift tcase from a 4Runner or FJ, I picked mine up from a totaled 5th gen 4Runner with 15k on it for $375 on eBay. Just try to make sure it comes with the shifter.
    edit:https://www.tacomaworld.com/threads/how-to-deleting-add-system.427258/
    edit 2: wait a minute disregard that, those are the parts you have currently on your clamshell, I actually do not know the part numbers for the add
  10. Jan 19, 2020 at 8:53 PM
    DG92071
    DG92071 Well-Known Member
    I thought the FJ with a automatic had a manual shift t-case like an old school t-case but you're saying it has automatic differential disconnect, are you sure?
    I'm not saying you're incorrect, in fact it's most likely I'm incorrect, I just want to know for sure is all.
  11. Jan 19, 2020 at 9:00 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Do a SAS and you can have all of the locking hubs you want.
    MY50cal and DG92071 like this.
  12. Jan 19, 2020 at 9:46 PM
    Bishop84
    FJ Auto has a J shift transfer case ya, but its a standard 2H 4H 4L. So it has an ADD due to no transfer case differential. 2WD means unlocked front axle.
    Manual has J shift 4H 4HL and 4L, 4H is AWD like a subaru. 4HL is tacoma 4H. Front axle always engaged, hence why Tacoma guys like buying the front tube ADD delete from FJ.
    4runner offroad and pro still have the J shift. both are tacoma style without the center diff. Only limited has center diff.
    bijick and DG92071[QUOTED] like this.
  13. Jan 20, 2020 at 5:57 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    If you sell your manual trans, AWD transfer case, put me first in line. Heck...let's just do a gear box swap. My low mile all-auto setup for your all manual setup?!?
    Manual trans, AWD DCLB is the truck Toyota should have built for me in the first place. Once the truck isn't my DD and has accumulated a few more miles, I'll be looking to do the swap.
    Also, OP: clean your MAF sensor and throttle body, then reset the computer by pulling the negative battery terminal for 10 minutes or so. Check air filter, tire pressure, fluids and lube your driveshafts (you know...all the normal fuel economy wear items). After that, look in to HP Tuners and tuning the truck. After tuning, my fuel econ (and driving enjoyment) is noticeably better.
    DG92071 likes this.
  14. Jan 20, 2020 at 8:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  15. Jan 20, 2020 at 8:44 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
  16. Jan 20, 2020 at 1:46 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
