07 flush and fill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlcjr, Nov 29, 2009.
  1. Nov 29, 2009 at 9:21 AM
    jlcjr
    jlcjr [OP] Member
    Lincolnton County GA
    07 basic, 03 Jetta TDI
    city truck, I've searched thru all of the scheduled maintenance and cannot find the suggested mileage for the ATF fluid. Will y'all enlighten? Truck is shifting strange, it goes thru a second or so of alternating RPMs when cold after slowing down for the speed bumps in my Hootie toote gated subdivision .
    Deep in Dixie
  2. Nov 29, 2009 at 9:25 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw.
    the sealed tranny's are supposedly good to go, then need to be flushed/filled at 100k.....unless you do alot of towing and such.
    if its shifting strange........it will a bit in the cold,drive by wire system...has to heat up to normal operating temp to shift optimally. take it and get the fluid checked................the 06 i had shifted late..took it in for a check...it was a quart low from the factory.
  3. Nov 29, 2009 at 9:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It may be downshifting to a lower gear....
  4. Nov 29, 2009 at 9:28 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    100,000 miles; 60,000 if towing. Even though I don't tow anything I personally will do it at 50K.
  5. Nov 29, 2009 at 9:32 AM
    jlcjr
    jlcjr [OP] Member
    Thanks for the knowledge !!
  6. Nov 29, 2009 at 9:49 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
