07 front diff help???
Discussion in 'Technical Chat' started by Nelz1, Sep 19, 2011.
  1. Sep 19, 2011 at 6:21 PM
    Nelz1
    Nelz1 [OP] Well-Known Member
    Boston
    07 Tacoma DC TRD
    Bilstein 5100 leveled bed panels fabricated, bed d rings, fog light mod.
    I have some pretty good loosness on my driver side inner cv joint.
    A while back the truck was in a collision that directly affected the left wheel.
    I've just replaced the entire left axle and the play is still there???
    I thinkthe play is just inboard of the dust seal Is there a bearing right there that may have been damaged in the accident????
    Any one know where there are any diff images
    Thankyou!!!!!
  2. Sep 19, 2011 at 6:25 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Sep 19, 2011 at 6:34 PM
    Nelz1
    Boston
    07 Tacoma DC TRD
    Its not some its excessive play It used to be normal like the other side
  4. Sep 19, 2011 at 6:36 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    Man it seems like vehicles never ride the same after being involved in an accident. Wish I had an answer for you.
  5. Sep 29, 2011 at 1:17 PM
    Nelz1
    Boston
    07 Tacoma DC TRD
    Atter convincing myself that the front end slow shudder while turning was my CV it was not.
    I went as far as replacing a cv axle playing around with shiming the diff and it was none of that.
    I brought the truck into a transmission shop and they diagnosed the problem as bieng the rear LSD ( it wasnt working properly so it was binding up when turning slowly). The shop changed the fluid, put in some additive and its fine now.
    P.S. The shop trouble shot the front by disconnecting the front driveshaft and ruling out everything up front!!
  6. Oct 1, 2011 at 8:20 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
  7. Oct 1, 2011 at 11:38 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    There is usually more play on drivers side.
