07 miss fire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by josh2002, Mar 18, 2012.
  1. Mar 18, 2012 at 8:13 PM
    josh2002
    josh2002 [OP] Active Member
    Hi u can call me stupid or whatever lol I just don't get it it's been to two toyota dealers and they don't know why it goes in limp mode it always show cly 6 miss fire I had replaced the computer and coils and injectors has anyone had this problem
  2. Mar 18, 2012 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Whats the code?
  3. Mar 18, 2012 at 8:26 PM
    josh2002
    I just scanned it again it shows a po300 random/multiple cylinder misfire
    And a po306 cyl 6 misfire
  4. Mar 18, 2012 at 8:33 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Can I assume if you changed the ECM, the coilpack, and injector that the sparkplug(s) have not been overlooked? If so, check for a vacuum leak in the #6 intake runner area. And do a compression test, or better yet, a leakdown test. Valve clearance would be another thing to check if nothing else turns up.
  5. Mar 18, 2012 at 8:39 PM
    krans
    krans Well-Known Member
    Kenny
    Huntington beach/ West min duh
    09 Sport mall crawler
    Icon extended travel with resi front and rear,Camburg UCA, All pro standard leaf pack, Fogs anytime, General grabbers AT2,Custom stainless steel brake lines,bed box, Bestop soft top,50' light bar, amber rigid pods,CBI ditch mounts with LED pods,TRD intake,Anti dark hoodlights/rock light/LED whip,FX-R retros and Gibson catback..more mods to come
    That's weird how two dealers couldn't figured it out, but how many miles on the engine?
    If your having Random/multiple misfires The engine may need a valve adjustment.
  6. Mar 18, 2012 at 8:40 PM
    josh2002
    Lol ya I replaced the plugs and I forgot to mention toyota said the engine was bad in that cyl but I have replaced the engine and they checked I guess the compression and leak down and it check out good it's a stupper lol thank you all for the hints and advice
  7. Mar 18, 2012 at 8:43 PM
    josh2002
    Ya it is crazy it has been in and out of the dealer I mean dealers for a yr lol it says random now but 90% of the time it is number 6
  8. Mar 19, 2012 at 7:02 PM
    josh2002
    It don't do it all the time it's intermitting
  9. Mar 19, 2012 at 8:04 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    What he said.
  10. Mar 21, 2012 at 10:11 AM
    josh2002
    Ok an update there is no vac leak im going to check the valve clearance hopefully this week
  11. Mar 21, 2012 at 2:18 PM
    1GR
    Scott
    BC, Canada
    You mean your shop/dealer is.. Right? Unless if you are mechanically inclined enough to know what you are doing.
  12. Mar 21, 2012 at 7:15 PM
    josh2002
    I checked the vac leak the dealer is going to do the valves and they are the ones that did the coils injectors and new cats and computer that was all done by a dealer
  13. Mar 21, 2012 at 7:37 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Just curious, but did you use OEM toyota spark plugs? I used champions and I got a missfire.
  14. Mar 21, 2012 at 7:54 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    This sounds like it could be a bad head gasket.I Recently had 05 4runner with 100k also cyl#6 missfire.Replaced plugs fuel injector finaly the customer told me that the miss only happend after the vehichle sat for a while.After that I pressure tested the cooling system found a very slow pressure drop.Next i used a borescope to find a very small amount of coolant leaking from the head gasket into the #6 cly.This would be a good test to perform before having your valves checked.The leak will get worse
    over time.One odd thing is the 4runner never smoked and the coolant resivor was not very low.Hope this helps.
  15. Mar 22, 2012 at 7:11 AM
    josh2002
    Oh no kidding ya I got the plugs from the dealer so they are oem
  16. Mar 22, 2012 at 7:16 AM
    josh2002
    Ya that dose help I will have that checked but the weird thing is it will go into the limp mode and run like shit but as soon as I shut it off and start it again it clears out and it did it with the engine b4 and toyota put all that stuff on then said it was the motor and so I bought another used one and did all the test on it b4 I but it in and I didn't even go 5 miles b4 it did it for the 1st time it hasnt got any worse it's been doing it for almost two yrs
  17. Mar 22, 2012 at 7:44 AM
    josh2002
    Dose anyone think it possibly be the engine wiring harness?
