07 Taco Engine & Tranny Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mint07trdsport, Nov 21, 2015.
  1. Nov 21, 2015 at 8:34 AM
    mint07trdsport
    mint07trdsport [OP] New Member
    07 TRD Sport
    I'm considering swapping out my 4.0l six for a 06-07 vvti 4.7l V8. I understand the 06 Tundra went from a 5 speed manual to a 6 speed manual with the 4.7l vvti that year.
    Although they are very similar to the first gen tundra, I know these trucks are not the same size and, do not share the same chassis.
    Question; Is this swap doable today? I know it was done for a SEMA show. Will the 06 Tundra 4.7 vvti and 6 speed manual mount without difficulty in my 07 Tacoma TRD Sport? I understand that a new ECU, accessories and exhaust will be required.
    I would appreciate positive advise on this.
  2. Jan 24, 2017 at 2:57 AM
    Whiskywolf07
    Whiskywolf07 Member
    Brian
    2008 Toyota Tacoma v6 4.0 off-road 4X4
    Upgraded tires to KO's (aggressive tread)
    Wow I could use the same answer... sucked water through the intake bent a connecting rod probably a valve too.. thought if I'm gonna tear into it.. what if I just picked up a 4.7 and through it in...to bad no help.. seems a rare build.
  3. Jan 24, 2017 at 5:04 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    the 4-runners of similar vintage came with V8's as an option (sorry, I don't know what size they were). Doesn't that have a similar frame setup as the Tacoma?
    Whiskywolf07 likes this.
  4. Jan 24, 2017 at 5:36 PM
    Whiskywolf07
    Whiskywolf07 Member
    Brian
    Yea from the sounds of it a lot of people either recommend the 4Runner or Lexus 4.7.. too bad I haven't came across a complete build yet.. you'd think more people would have turned that rad little taco into a v8
  5. Jan 24, 2017 at 8:23 PM
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    Well the v8 isn't much more powerful, it's considerably heavier and less fuel efficient. The op is wrong in saying the tundra had a manual transmission as well.
  6. Jan 25, 2017 at 2:47 PM
    Whiskywolf07
    Whiskywolf07 Member
    Brian
    Yea I read the v8 only comes in auto.. which means you have to trick the obII to accept the manual transmission.. so bottom line a bent a connecting rod and maybe a valve not for sure yet haven't torn it apart but was thinking would it be more cost effective to just swap out with another v6? It's an 08'taco and I'd have to pay for the work to get done being I'm at a shortage with tools. Got water in through the intake.. apparently I didn't mod/water seal it.
