07 Taco Front Crank Seal Leaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by restless badger, Jan 13, 2010.
  1. Jan 13, 2010 at 4:51 PM
    restless badger
    restless badger [OP] Well-Known Member
    Bryan
    Justin, TX
    07 Dbl Cab SR5 TRD Sport 4x4 V6 Silver Streak
    ProComp 265/70/17 M/Tx, K&N cold air intake, Kenwood DVD,Nav,touchscreen, OEM bed extender, bed divider, Lo-Jack,Revtech susp, Smitty Built Bull Bar, Hella Lamps. Rear Leaf TSB
    Ok guys need some advice. I searched around and found a couple of different TSB's on this problem. My truck has 79k miles on it so the 5yr/60k warranty is out. My local Kwik Kar oil change says they can do it for $245.74 but I'm kinda worried about having my truck worked on by a quick lube joint. They take good care of my truck for oil changes but never have actual work done there.
    What do the experts out there suggest?
    Thanks,
    B
  2. Jan 13, 2010 at 4:54 PM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
  3. Jan 13, 2010 at 4:58 PM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    never let a quick lube place do it...search for locals taco on the forums, find and make freinds, buy a case of beer and buy lunch, and i am sure youcan find someone here to help you do it yourself, and you will learn how to. if money isn't a problem go to the stealership.
  4. Jan 13, 2010 at 5:24 PM
    restless badger
    Bryan
    Justin, TX
    I agree on the quick lube shop.
    Chester thanks for the link. I actually read that one. I love my Taco and I'm just bummed to have to spend money on an oil leak. Not what I expected from Toyota. But hey, it's still a great truck.
  5. Jan 13, 2010 at 5:49 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Does the leak drip on the ground or do you have to crawl under the truck and look?
    Any idea if the cause is a problem on all 07 Tacomas ?
  6. Jan 13, 2010 at 6:01 PM
    restless badger
    Bryan
    Justin, TX
    yes it drips on the ground. the odd thing is I just had the oil changed which is why I took it back to kwik kar. i thought it was a loose filter or some overflow from the filter housing.
    from what i have read it's a common problem. i think (hope) toyota should take care of it being a common problem. but i may be out some $$$ it sounds like. :mad:
  7. Jan 13, 2010 at 6:26 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Defroster mod, Bilstein 5100s front, Adjustable Ranchos rear.
    If it's like the rest it's the timing cover leaking. Known problem that has a tsb on it. You might want to take it to the dealer and complain about this obvious design flaw. They might give you half off.
  8. Jan 13, 2010 at 9:49 PM
    restless badger
    Bryan
    Justin, TX
    cool thanks
