07 Taco TRD sport v6 rough start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dmeverett44, Apr 13, 2016.
  1. Apr 13, 2016 at 3:25 PM
    Dmeverett44
    Dmeverett44 [OP] New Member
    Have had my 07 taco for a couple of months now. Has been running great but recently it starts a little rough after sitting for a while and it seems to have been getting a little worse. I have a few ideas of what it could be but would like to hear what you all think. Thanks!
  2. Apr 14, 2016 at 5:32 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Mileage? Remember, Tacomas do not have iridium plugs and therefore need changed every 30k. I personally ran mine accidentally for 60k with no issue and I have heard of guys running 100k. I also run a bottle of Techron through every once in a while, it can't hurt. I am however not a big Seafoam fan.
  3. Apr 14, 2016 at 6:17 PM
    Dmeverett44
    It has 170k
  4. Apr 14, 2016 at 6:19 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    When is the last time you put plugs in it? When was the last time you put a PCV valve in it? I traded my 06 in with 175k and quite honestly it ran as smooth as it did when it was new. It should not be running rough.
  5. Apr 14, 2016 at 6:22 PM
    eon_blue
    Azusa, CA
    Do you have the maintenance records? If so, check and see if the plugs have been changed recently. If not, that'd be a good place to start.
  6. Apr 15, 2016 at 12:41 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Could be a bad head gasket, iirc there were a few reports of earlier 1gr-fe having a weak spot in head gasket. I think it was reported to cause a misfire on Cylinder 6. I want to think they changed the head gasket design sometime in 06, not positive on that though.
  7. Apr 15, 2016 at 7:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is a four cylinder it would have iridium tipped plugs.
