'07 Taco Won't Blow Hot Air Unless Driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roden011, Dec 26, 2013.
  1. Dec 26, 2013 at 10:00 PM
    roden011
    roden011 [OP] New Member
    07 PreRunner SR5
    I've got an '07 Tacoma (PreRunner 4.0L). I've recently noticed that unless I'm driving, my truck won't blow hot air, even if I let it come up to temperature. Once I start driving and get the RPM's up, the hot air is fine. Also, if I'm parked, if the truck has warmed up and I rev the engine, it'll start blowing hot air, briefly. The temp gauge holds steady at the center of gauge once it comes up to temp. Any ideas on what the problem is and how I might fix it? Thanks in advance for your help!
  2. Dec 26, 2013 at 10:19 PM
    A3umph
    A3umph Well-Known Member
    outside of KCMO
    '12 Tacoma Access Cab TRD OR
    With the engine cold take off the radiator cap and check the level of the antifreeze.
  3. Dec 26, 2013 at 10:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Most likely low coolant level.
  4. Dec 26, 2013 at 10:47 PM
    wibbly wobbly
    wibbly wobbly New Member
    Connecticut
    09 Tacoma
    My Tacoma recently started doing the same as well.
    It also takes longer than normal to blow warm air when driving. Driving on the highway it blows heat at the normal, hot, temperature. Idle for a few minutes in parking lot and it blows lukewarm.
    Coolant level is well above the minimum level in the overflow tank. This might be a dumb question, but that means I'm at the correct level right? Or do I have to check what is in the radiator itself?
    I've heard that this could be caused by an air bubble in the heater core - could I have one of those and still show the proper level in the over flow?
    No leaks anywhere. No odd noises from the water pump that I can notice.
    Temperature "gauge" goes right up to the middle and stays there. I plugged in my scan gauge and i'm showing the coolant temp at a consistent 184 degrees. I've heard that if the gauge works that it probably isn't a thermostat.
    Changing the temperature setting will blow cold air or a mix so I have eliminated a malfunction in the blend door as a possible problem.
    Heater core going bad? (maybe…) Is my water pump not circulating coolant correctly? (seems unlikely)
    It's an 09 Tacoma 4.0L. Bone stock. Just hit 110k. Coolant was flushed and replaced at 100k about 6 months ago.
    thanks in advance.
  5. Dec 26, 2013 at 11:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I think you have an air pocket trapped in the system.
    Warm up the engine and then when it is fully up to temperature massage ( squeeze ) the radiator hoses to work out the air. Trust me this does happen all the time esp after a coolant drain flush etc.
  6. Dec 28, 2013 at 4:38 PM
    toyo8696
    toyo8696 Well-Known Member
    Cumming,GA
    4X4 Sport DCSB, 2008 4R V8 AWD
    You can also do some tight figure 8's in a parking lot. Hold the throttle at about 3K RPM's for 2 minutes. The last one is what Ford and GM specify to remove air pockets.
  7. Jan 19, 2014 at 2:57 PM
    wibbly wobbly
    Connecticut
    09 Tacoma
    heater core was blocked. was able to make it a little better by flushing it, but ultimately the whole dash had to come out so a new heater core could go in.
  8. Jan 19, 2014 at 4:50 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What was it blocked with? There shouldn't be anything in the cooling system that would ever block the heater core. Ever.
    Did you do it or did someone else find it? Someone else, I Think you got taken for a ride. I have enever seen a heater core get plugged unless the system was contaminated or some idiot put an excessive amount of "Stop Leak " in the cooling system. Stop Leak is also a contaminate IMO.
    If the heater core was blocked the radiator should be blocked also.
  9. Jan 19, 2014 at 4:55 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Heater cores get plugged all the time. Calcium and crap builds up in them and they need to be flushed. Pretty common here because everyone uses their heat and notices when it's not blowing hot enough.
