07 Tacoma actuator??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RoosterH, Jan 1, 2022.
  1. Jan 1, 2022 at 11:36 AM
    RoosterH
    RoosterH [OP] Member
    Does anyone know where the ground is at for the actuator??
  2. Jan 1, 2022 at 12:05 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Actuator for what? It would help if you gave a bit more info.
    TnShooter likes this.
  3. Jan 1, 2022 at 7:54 PM
    RoosterH
    Both transfer case and front diff?
  4. Jan 1, 2022 at 7:58 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The limit switch grounds are on the top rear of the passenger side cylinder head, the actuator motor powers and grounds are controlled by the 4wd ECU which is grounded behind the passenger side kick panel.
    See my thread below for more info on the 4wd system including wiring diagrams and ground locations.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
  5. Jan 2, 2022 at 10:55 AM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    Dm93 I want to thank you for all you contribute to this forum
