07 Tacoma - Driveline Clunk/Grinding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BluberryBCtaco, Apr 25, 2023.
  1. Apr 25, 2023 at 5:35 PM
    BluberryBCtaco
    BluberryBCtaco [OP] Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Hi there,
    Can anyone help me identify what Clunk is?
    https://youtube.com/shorts/yzNinw3TTFk?feature=share
    Had a buddy hold the break hard to the floor, with the parking break set. While shifting in drive then reverse.
    Similar issue when driving I let off the accelerator to coast, a rubbing/grinding noise appears.
    Disappears when I put little bit of acceleration.
    Noise varies from coming from rear, to front, to middle.
    Spider Gear? U-Joint? Differential? Transmission?
    I'm getting the center support bearing/ busing swapped.
    07 Tacoma DL Sport
  2. Apr 25, 2023 at 5:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like u-joint slack/wear.
    If you’re doing the center/carrier bearing, do the u#joints at the same time.
  3. Apr 25, 2023 at 5:52 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I see a lot of movement at the u-joint near the CB.
