07 Tacoma popping sound when turning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brobsty6526, Feb 14, 2018.
  1. Feb 14, 2018 at 10:39 AM
    Brobsty6526
    Brobsty6526 [OP] Member
    Corey
    07 Tacoma double cab
    3in rough country lift, ATX mojave 2 wheels
    Hey been having a popping sound ever since I lifted my truck I have a 3 in spacer lift from rough country. Every time I turn into a parking spot I get a popping sound. I replaced the sway bar links a few weeks ago but that wasn’t it. Any thoughts?
  2. Feb 14, 2018 at 10:43 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Are you 4x4? Probably your cv axles
  3. Feb 14, 2018 at 11:06 AM
    Brobsty6526
    Corey
    Yes and don’t think it’s that it sounds like a hammer to a plate of steel
  4. Feb 14, 2018 at 11:07 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Maybe your coils are binding? Can you post a pic of your shocks?
  5. Feb 14, 2018 at 11:11 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Tighten everything. LCA cam bolts are a common culprit, but also check your lower shock mounts. Check the torque ratings and lean into that breaker bar. Works for a lot of people here.
    Once you eliminate that, it might end up being something internal.
    Good luck and welcome aboard.
    scottalot likes this.
  6. Feb 14, 2018 at 11:13 AM
    GHOST SHIP
    GHOST
    The "ping" of steel might be misleading. It's usually the rotor backing plate that is resonating any vibration or movement in your front end, not always something actually hitting.
  7. Feb 14, 2018 at 11:13 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    My guess is that your sway bar link is broken.
  8. Feb 14, 2018 at 11:37 AM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
    Could also be part of the steering rack binding because there is too much lift in the front - buddy had this happen on his 1st gen after he did a body lift on top of his regular lift. Ended up lowering the front back down. No clue what the differences are between 1st and 2nd gen steering racks though.
  9. Feb 14, 2018 at 11:40 AM
    Brobsty6526
    Corey
    I removed the sway bar at one point and that didn’t do anything still had the sound was told that it could possibly be the mount for the skid plate. It’s in stock coils.
  10. Feb 14, 2018 at 11:42 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    If it happens when you turn while in reverse and it is a pretty decent pop sound it probably is the LCA bolts. My front end had been making the noise when reversing out of my driveway and when cranking the wheel when pulling out of parking spots. Recently just got an alignment yesterday and most of this has resolved but slightly still there. The LCA bushings are probably just wore out compounding the issue. Most say retorque the LCA bolts and see if it goes away.
    devkurf likes this.
  11. Feb 14, 2018 at 11:46 AM
    Clearwater Bill
    Billy
    Largo Florida
    Did your 3" come with new control arms? Have you had an alignment since your install?
    A crackerjack front end guy (usually not at big box stores) should find the problem in the process of doing the alignment.
    And as @GHOST SHIP suggested, make sure things are properly torqued. If they are mounted in bushings that torquing must be done with the suspension in compression, not in droop.
    GHOST SHIP likes this.
  12. Feb 14, 2018 at 11:47 AM
    Brobsty6526
    Corey
    Probably could use an alignment I could try that I’ve been wondering if it’s the mounts for the skid plate. I have the front diff spacers installed but never cut the mounts like it said to.
  13. Feb 14, 2018 at 11:48 AM
    Brobsty6526
    Corey
    No new control arms and had an alignment about 3 weeks after install
  14. Feb 14, 2018 at 11:49 AM
    Brobsty6526
    Corey
    Eventually I’m gonna upgrade to a 6inch lift this spacer shit sucks very rough ride
  15. Feb 14, 2018 at 12:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :anonymous:
  16. Feb 14, 2018 at 12:37 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    “Upgrade” lol
  17. Feb 14, 2018 at 5:11 PM
    Brobsty6526
    Corey
    Maybe next year I will need to fix this problem in the mean time
  18. Feb 14, 2018 at 5:16 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Tie rods
