07 Tacoma starting hesitation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dougmays, Dec 11, 2008.
  1. Dec 11, 2008 at 5:46 PM
    dougmays
    dougmays [OP] Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    i have a 2007 Tacoma (bought in april 07) with 34,000 miles on it. I just had my 30,000 mile checkup and it seems since then i've had starting hesitation. Almost as if my battery is not fully charged. anyone experience this at 34k? they replaced my spark plugs at my 30k checkup so i would assume i'm getting good spark. and i would hope that my battery lasts more then just a year and half.
    any ideas?
  2. Dec 11, 2008 at 5:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    there is a tsb for "intermittent no start" or extended cranking.....something along those lines. i had it done on my 06, since i was having the same peoblems, and it took care of it. they need to reflash your ecu!!
  3. Dec 11, 2008 at 8:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Mine does it twice a month maybe? My truck is only 2 years old w/ 13K miles on it.
    Tacomaman - how often was yours doing it before you got the TSB done? And did the dealership have to see the problem before performing the TSB?
  4. Dec 11, 2008 at 8:18 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I have been expierencing this lately and im not liking it looks like i will be taking it in to get checked out and i only have 27,000 miles on it my volts are fine according to my scangauge.
  5. Dec 11, 2008 at 8:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    actually.........mine would happen about 2 times a week, and so i got tired of it and went in. they did it...no questions asked, which kinda surprised me.:D but it took care of the problem when they reflashed it.
  6. Dec 12, 2008 at 6:43 AM
    dougmays
    Doug
    Gainesville, FL
    Thanks for all the info guys....Tacomaman....is there a TSB number or anything for me to give them when i go in?
  7. Dec 12, 2008 at 7:04 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  8. Dec 12, 2008 at 10:12 AM
    Janster
    Jandy
    Lancaster, PA
    Thanks!
    Not happening enough to worry about it yet. I've got another year left on warrantee (unless we buy the extended one). Wonder if that has anything to do with what seems to be a minor surging at idle? I'll be sitting somewhere (stop light, drive-thru, whatever) with brakes on sitting still and the rpm's (according to scangauge) goes from 650ish down to 550is, then back up to 650, down to 550, up to 650, down to 550. Weird. If I didn't have this exhaust, I probably wouldn't notice it ramping up/down.
  9. Dec 12, 2008 at 11:44 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it sounds like it could have a bit to do with it, especially if the ecu is sending mixed signals. reflashing the ecu will more than likely take care of that annoyance too.
  10. Jan 18, 2009 at 1:28 PM
    dixieboy01
    dixieboy01 Member
    Cabot, AR and Abbeville, SC
    08 SPORT 4X4
    Anyone having this problem with the 08 year model?? Mine only does it when it sits for for a few hours but never when it sits in the garage overnight, it's kind of crazy. I took it in to the dealership and they couldn't do anything with it. Now when I go back I will have this tsb to work off of. Thanks.
  11. Jan 18, 2009 at 1:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw!
    some are infact still having the problem on their 08 models. dealerships are not doing anything to help since the tsb was for 05 and 06 tacomas, and maybe some 07's. something you can do..............pull your plugs and check the gap...should be around .040...............regap them......should help a bit.
  12. Jan 18, 2009 at 2:47 PM
    Snyperx
    Snyperx Seniore Marcos
    Mine started doing this shortly after I bought it used in 2007. happens very sporadic. I took it in, but of course it would not do it at the dealer so they could not fix it. It did it again here a few weeks back, but I am not going to waste two hours at the dealer. They will just come back again and say they could not find anything wrong and not do anything to fix it. My dealer is not good and doing a TSB that is requested. They also don't seem to like customers that do homework.
  13. Jan 19, 2009 at 9:19 AM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    This has been happening to my truck a few times a week.Joy a trip to the dealer!AWESOME!
  14. Jan 19, 2009 at 9:51 AM
    dixieboy01
    dixieboy01 Member
    08 SPORT 4X4
    I read the original topic wrong...mine acts as its not going to start it just spins like the theft deterrent system is taking control. After a few tries its like there isnt enough fuel in the system and kind of a rough start until it gets enough fuel. Is this happening here too?
  15. Jan 19, 2009 at 10:45 AM
    mpreiss
    mpreiss Attack Life.
    Capon Bridge, WV
    07 D.cab 4x4 w/3" Lift
    3" Pro comp Suspension Lift Fog light Mod. Tinted Front windows 15% (match rears) Tonneau cover Halo head lights K&N filter.
    This is kinda what mine seems to do. Like you have to hold the key for longer then you would assume. Exactly like there isn't 'nuff gas right there ready to fire. But it seems like it has been the same ever since i bought it new in Feb. of 07
  16. Jan 19, 2009 at 2:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not sure if ya'll have tried this, but if ya havent...give it a go...really makes a difference.
    when you go to crank the truck...turn the key till you hear the fuel pump prime, but dont crank it immediately, then after a few seconds....crank her up. she should fire up pretty quick after the fuel pump is primed.
  17. Jan 19, 2009 at 4:13 PM
    Snyperx
    Mine goes in on Wed. for this. I have a 2005 Double Cab. I have the issue where the engine turns over fine, but never starts. I take the key out, wait a few seconds, put the key in and it then starts fine. No rhyme or reason to what is causing it. It happens when it is cold out or warm out. I am hoping they will do the TSB on it.
  18. Jan 19, 2009 at 4:42 PM
    dixieboy01
    dixieboy01 Member
    08 SPORT 4X4
    Yeah Ive tried the wait to start thing and it still does it. Toyota has to know about this problem if there is so many people having it. It makes me so mad when it does it.
    Snyperx keep us posted on what happens Wed. Im going to take mine in soon and get them to look at it...again.
