07 Tacoma Torque Specs for drive shaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SEAustin87, Mar 31, 2011.
  1. Mar 31, 2011 at 10:47 AM
    SEAustin87
    SEAustin87 [OP] New Member
    07 PreRunner SR5 OR 2WD Rear lock slip diff
    None yet
    I've been trying to find the torque specs for the drive shaft in an 2007 Toyota Tacoma Double Cab V6 TRD Off Road Package 2WD with the rear locking slip differential. I replaced all three u-joints yesterday because I finally got tired of the vibrations and squealing and it seems to be running much better... but I couldnt find the torque specs for the 4 bolts that connect the flange and the diff and also the 2 bolts that hold the middle of the shaft to the frame. I have them on there as tight as I could get them but would like to know the actual specs to make sure its up to par. Thank you in advance.
  2. Mar 31, 2011 at 11:04 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I believe the answer for the four bolts is this: Torque: 88 N*m (899 kgf*cm, 65 ft.*lbf)
    The center support bearing with the 2 mounting bolts is: Torque: 36 N*m (369 kgf*cm, 27 ft.*lbf)
    Found here: From here: Welcome to the forum!!! :wave:
    deanosaurus likes this.
