07 Tacoma v6 blown
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Goneloco77, May 15, 2023.
  1. May 15, 2023 at 4:11 PM
    Goneloco77
    Goneloco77 [OP] Member
    Enrique
    2007 Black Tacoma regular cab RWD
    Hello everyone friend of mine has a 2007 Tacoma v6 can a inline 4 from same gen be swapped in and if any fab work has to be done ?
  2. May 15, 2023 at 4:26 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Not just a swap of engines, you will need the ECU, and a few other things
    Goneloco77[OP] likes this.
  3. May 15, 2023 at 4:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Can it be done. Yes.
    Would it be feasable/cost effective. Probably not.
    At a minimum along with the engine you would need to swap:
    PCM
    Engine and transmission wiring harness
    Transmission
    Exhaust system
    Not sure why you would want to go from a V6 to the 4 cyl, most people want to do the opposite.
    I believe the 2.7L costs almost as much if not more the 4.0L in the used engine market.
