08 2.7l 2wd lift
Discussion in 'Suspension' started by maxmyster, Jul 18, 2008.
  1. Jul 18, 2008 at 3:18 PM
    maxmyster
    maxmyster [OP] Member
    canada
    08 yota 2.7l acces cab
    hi i got a 08 2.7l access cab 2wd tacoma and i was wondering if procomp made lift kit for it. i noticed on their website that they had the 07 models but no info on the 08 models.
  2. Jul 18, 2008 at 3:21 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    08's and 09's are the same suspension wise as the 05-07
  3. Jul 18, 2008 at 3:23 PM
    maxmyster
    canada
    thx for that ill now be able to check out on ebay for some parts.
  4. Jul 18, 2008 at 3:25 PM
    maxmyster
    canada
    can you tell me what ppl mean when they say they got a 5lug yota?? is it the number of nuts on wheel rims??
  5. Jul 18, 2008 at 3:27 PM
    The_Hodge
    SC
    yeah...5 luggers means how many wheel studs they have. they have a different suspension set up than a 6 lugger
  6. Jul 18, 2008 at 3:28 PM
    maxmyster
    canada
    soo i gotta make sure what i buy is compatible with my 5 lugg
  7. Jul 18, 2008 at 3:30 PM
    The_Hodge
    SC
    definately...the rear set up on 5 luggers is a lot different for sure (ie springs under the axle instead of over the axle on the 6 luggers), but i think there may be differences up front as well...not 100% on the front though
  8. Jul 18, 2008 at 3:35 PM
    maxmyster
    canada
    hey an other question how i know if my truck is a prerunner?? i got a 2008 acces cab 5spd manual 2.7l
  9. Jul 18, 2008 at 3:56 PM
    The_Hodge
    SC
    urs is a 5 lug, so no prerunner...a prerunner is a 6 lug truck thats 2wd that has the same height/suspension as the 4wd
  10. Jul 18, 2008 at 4:00 PM
    maxmyster
    canada
    yea its the 4 door one i rememember now
  11. Jul 18, 2008 at 4:18 PM
    rick
    rick `
    if its a 4x4 its not a prerunner
  12. Jul 18, 2008 at 7:59 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I don't mean to come off like an ass hole but how can you not know what truck you own?
  13. Jul 19, 2008 at 4:03 PM
    david04
    david04 Member
    Theres not much option now for lifting.
    There are lift kits by readylift.com which will raise the front and back for $329.99
    readylift.com
    You can also use the Pro-Comp lift kit which is meant for the prerunners.. but it'll work for the 5lugs
    http://www.customtacos.com/forum/showthread.php?t=114993
    if you're hardcore theres the total chaos setup which runs for about $1000
