08 6spd manual trans problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rollcage, Aug 21, 2011.
  1. Aug 21, 2011 at 8:43 AM
    rollcage
    rollcage [OP] New Member
    fountain CO
    08 Tacoma
    I have a weird issue with my 6spd manual. Recently it seems to shift funny into 1st gear. No grinding. While shifting normally into gear you would feel it transition through a hard point mid way through the stroke, maybe when the gears are meshing. Now I don't feels this and I have to push fairly hard at the end of the stroke for it to stay in gear, if I don't it while grind as if it's not all the way in gear. Anyone had this issue, or heard of it?
  2. Aug 21, 2011 at 8:55 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Is this only in first gear? if its all gears it would most likely be your clutch.
  3. Aug 21, 2011 at 8:58 AM
    chozomo
    chozomo Active Member
    Adam
    Vermillion, Alberta
    10 DC TRD White, 92 SR5 pickup
    Extra fuel tank, fire ext, light force driving lights , TRD exhaust, ARB and Warn winch, Bushwhacker, toytec ultimate lift, dakar leaf springs, 18' ATX thugs
    mine dose it to for some reason. But its just when its cold
  4. Aug 21, 2011 at 10:08 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I occasionally have trouble shifting mine into first after sitting in neutral. A second pump of the clutch and it shifts fine. Not sure why.
  5. Aug 21, 2011 at 1:24 PM
    Mr.Tacoma
    Mr.Tacoma Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    I never experienced such problems on mine.
  6. Aug 21, 2011 at 3:52 PM
    Freestyler
    Freestyler Well-Known Member
    Duvall Washington
    05 TRD off road
    6" Pro Comp, 315/70/17 Pro Cromp Xtreme mt on 17x8 ultra Goliaths, K&N intake, Westin Sportsman, Flowmaster Exhaust, Alpine Speakers and Amp, JL 8 Inch SUB, Pioneer AVH-P3300 BT, 35W 5k HID Healights and Fogs, 100W 6k HID converted 800 series KC Lights.
    I sometimes have a hard time getting it into first. try going down to second, then up to first. Usually does the trick for me.
  7. Aug 21, 2011 at 4:09 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    Thats what mine felt like at about 33K then the clutch went. No inspection cover to look inside. I went the next day.
